Thread: Summer Rains.....
    VladimirPutin's Avatar
    Apr 2015
    Orlando
    11
    Summer Rains.....
    I live in Orlando and it rains quite a lot lately. For some reason my Pool does not keep CYA, it always lowers somehow actually so i guess thats good? so we have been adding one 3 inch clorox trichlor puck a week which seems to have been doing the trick. Next thing you know its a war. pool goes green everywhere. Brushed it and dumped a bag of cal hypo. Pool starts clearing up and its looking good, did not get a chance to clean the filter yet due to the thunder storm. 1 storm later and the pool is getting green even after adding 3 pucks, my CYA is 45. argh
    Orlando, FL
    690
    Re: Summer Rains.....
    Hey neighbor! Yes, the rain has been a bit of a challenge for me too but only because it rains about 20 minutes after I get home from work, which means the kids are in for about five minutes before they hear thunder and get out.
    My CYA also goes down but that is because I keep it at 30...barely. I maintain a FC level around 4-5 and I do not have any issues with algae, even with the rain. I am using 10% chlorine from PaP and it is constantly fed when the pump is running for 5.5 hours each day.
    Once you get your algae cleaned up by SLAMming, You might consider keeping your FC a bit higher than you have been.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Quote Originally Posted by VladimirPutin View Post
    You have not stated your FC level. You should post a full set of test results (FC, CC, CYA, pH, TA & CH) and which test kit you are using.
    Also, please add your pool details to your signature, see mine as an example.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
