Thread: Small jets not spinning
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Some of the small rotary jets in my hot tub aren't spinning, some are. These jets are about 1 1/4 inches in diameter with 2 angled nozzles on them and a chrome ring around them that controls water flow. The flow control ring is wide open on them and they seem to have as much pressure as the ones that do rotate. They will turn by hand, so they aren't frozen up. They are on both banks or zones control wise, and some on the same gang turn, some don't. I have tried running just one bank to see if it was a pressure issue, but there wasn't any change in operation of the offending jets. All the large jets rotate fine.
    I ran a dose of Ahh-Some through it today during the routine cleaning, thinking maybe they were gunked up. No change, but I got plenty of gunk anyway. It was the first time I had ever used it, and I won't be without it after seeing what it got out of what I thought was a pretty clean hot tub.
    Any advice on what to do to those jets ? Anyone know how to take them apart without a major invasion of my entire plumbing system ?
    Hints, tips or tricks welcome.
    15x30 IGP; 20,000 gallons; plaster
    Hayward SP2607X10 Pump; Purex Triton Tagelus Sand Filter
    Hayward Goldline T-Cell 15 SWG; Aquarite G1 Control
    Southwest Spas 400 gallon hot tub w/ozone
    TF 100 with speed stir
    Casey's Avatar
    SW PA
    10,444
    Re: Small jets not spinning
    I'm not sure what you could do but I'm sure someone can help soon enough.
    Jun 2015
    Wildomar, California
    423
    Not sure of which spin jets you have but all of the types I've ever seen come off from the front if the jet in the spa
    Most usually twist off counter clockwise. Also a lot of them have small ball bearings in them that can break or fall out
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Does the chrome flow control ring come off with them, or does it have to be removed first ?
    Jun 2015
    423
    Yeah, its called a beauty ring. It comes off first. Then the whole jet comes off.
    Thimble's Avatar
    Apr 2013
    Wichita, KS
    93
    Thanks !
