Page 1 of 4 1234 LastLast
Results 1 to 20 of 65
Thread: Walls out of round
    Jun 2015
    Quarryville/PA
    58
    Walls out of round
    Working through the world's longest pool erection - -If Kim or Casey are there ~ still not swimming =(
    Our 27' round walls were set up for the umpteenth time and the pool was perfectly round and staked. 12 hours of beating winds and rain and the east side has 3 or 4 radius measurements that are short. Will these push out as the pool fills? will it be safe?
    Should I pay attention to the gaps in the track/base plates at those points? 18 posts and 14 of them are measuring 13' 5" to 13' 5 1/2". The shortest of the few is 13' 3 3/4".
    27' round ~ preowned ~ beginning install ~ replacing smaller pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,476
    Re: Walls out of round
    WOW! This HAS been almost as long as an inground pool build!
    Is it round? The track/base plates are meant to be adjustable. NONE of mine were the same on any two sides of a base plate. So long as your track as a whole is ROUND and your wall fits you are good!
    Do you want to take a pic and show us what you are talking about just to have more eyes on it?
    Kim
    Jun 2015
    Quarryville/PA
    58
    Very funny. Thanks for that. Ha! If you can believe, after my prior post (and weeks of my husband doing nothing), I came back from a week away and said the heck with it. "I'm doing it myself." I put up 27ft of wall to circle perfection and ran out of daylight before I could stake. In the morning my daughter and I started staking and out of nowhere (and 3 hrs before predicted) the wind picked up and everything started crashing!!! It was nightmarish. Buckles, out of track... My just prior proud self had to hold back the tears. (my daughter had enough for both of us) We live on a hill surrounded by open fields. The weather has not been my friend.
    As WE put the pool walls up I made sure we maintained equal radius from center to each baseplate. The storm/high winds lasted so long (this time) that it inched some of them in. Some were even off the blocks despite being staked. We corrected as much as we could, it seems, but a few of them are still measuring up to 2" shorter. Does that make sense? I wanted to unbolt and take that section down and try to do better but my husband thinks I'm nuts. Plus he has already leveled sand there. He thinks when we fill it will all even out. I don't need perfect, just safe. And hopefully durable!
    The wall is connected and in the track. I think it is buckling a bit at the bolted seem, but again....he thinks everything will work itself out?? (including the minor dents from our mishaps) Shouldn't I get some sort of award for this ?
    Jul 2012
    Tallahassee, FL
    30,476
    Safe or sorry? Which way do you want to go????
    Kim
    Casey's Avatar
    SW PA
    10,438
    Where are your walls buckling? Pics would be great. Also, al long as your wall is meeting up, your base plates are on your pavers, You should be able to proceed. I'd like to see pics of what you feel are your problem areas. It could help us, help you.
    Jun 2015
    Quarryville/PA
    58
    Thanks. Will do tomorrow. (pics)
    Hmmmm. If that's the case we could have continued the first time! (Shhhh) I kept reading it had to be "round" and no more than 1" out of round. Live and learn. Hopefully we're good. Had planned on full day today and filling ~ unexpected rain all day, hardly got anywhere. Between weather, baseball, vacation and those who fail to follow directions, what started out as a weekend project has become a daunting task. Delays and mishaps have created much more work than there would have been if everything had gone as planned. This is crazy.
    I will send picture of seam, minor dents and any questionable baseplates. Thanks again! I've noticed some people have problems posting pics? any tricks? Will check back in morning.
    Casey's Avatar
    SW PA
    10,438
    I use postimage.org. It's free and easy to use.
    Once water hits the liner and starts filing, it will gain it's true shape. As long as your base plates are on the blocks, you should be fine. You just don't want to be more than 1" out of level.
    Jul 2012
    Tallahassee, FL
    30,476
    And so long as some of the track is in the base plate you will be fine.
    Kim
    Jun 2015
    Quarryville/PA
    58
    Ok. then we should be good. I suppose if the wall isn't quite straight/perfect at the bolted seem that will straighten up too. I hate the thought that it may have been ok the first time, but then again, when he rechecked level of the blocks after the tear down, his friends did not have it right, so I guess that's good. The worst part of it all is that there are now imperfections in the wall, nothing major. I hope they push out as well. And the area around the pool is going to take a lot more work bc of the weeds that have grown. No, the worst part is that the kids lost a month of swimming =( I may not post pics if I go up there and feel good after seeing your comments.There is one about 1/2" segment at a plate where the base of the wall was damaged that I have to check. i didn't like the way it was seated in the track.
    Casey's Avatar
    SW PA
    10,438
    If your wall is jumping out of track, your not level. You have a low spot. If your wall is bulging at the bottom, you're not level. You have a high spot. Double check your pads now n make sure you're within an inch level. Get the wall in the track and bolt it up. Make sure your plates are on the pavers and prep the bottom for the liner.
    It would be nice to see pics on how you're progressing. They are mandatory!
    Jun 2015
    Quarryville/PA
    58
    Good Bad ???
    Not quite under lip
    Obviously, the second picture which the track is not quite under the lip of the plate on one side. Can't figure out how to correct with wall already in
    This is at only one plate. The rest are seated fine
    Jul 2012
    Tallahassee, FL
    30,476
    The pics are not showing
    Kim
    Jun 2015
    Quarryville/PA
    58
    Darn. I can see them. The walls aren't coming out. On one side of one baseplate - where the track slides in , the track isn't quite covered by the lip on the baseplate. It's either not slid in properly or something is slightly bent. Let me try something - tell me if you can see pic s good bad same one bowed???
    Jul 2012
    Tallahassee, FL
    30,476
    There they are! I see them and see what you are talking about. It does look like there is some bend in the base or track.
    Here are my thoughts-------------It looks like the track is down enough. As in the bottom of the track is sitting right on the top of the base plate. If I am seeing it right that is good. If not then gently tap the track down so it IS sitting on top of the plate.Then take some needle nose pliers and gently use them to "push" the two together they will seat together.
    Wall bow-I am not sure how to fix that. I am with your hubby that the water may "fix" it.
    Now please know I am NOT an expert! I am just giving you ideas of what I would do! I am not sure if it will work but my gut says it will. Use my ideas as you like or not.
    Good luck and HUGS!
    Kim
    Jun 2015
    Quarryville/PA
    58
    I do believe it is seated on the base plate. It's weird. No way to get the pliers in there to squeeze. It's as if it just wasn't slid in right. I thought of tapping the plate to the side and trying to reslide it it, but if I recall, there wasn't enough leeway with the gaps on the plates on either side. The bow -- I think we should undo the nuts and bolts and make sure they are tightened evenly from the middle up and down. Hand tighten first and then drill tighten. Only explanation I can think of. Wasn't like that the first time it was bolted =/
    Jul 2012
    Tallahassee, FL
    30,476
    I would NOT try to move the plate. Too much can go wrong.
    I really like your idea about the bolts-loosen and make sure to tighten it evenly. Good idea!
    Kim
    Casey's Avatar
    SW PA
    10,438
    Is that inside or outside of the pool on that base plate? The water should take care of that bow. It is behind an upright anyway. You may never see it.
    Jun 2015
    Quarryville/PA
    58
    It is on the inside. The bottom of the track is in the plate slot, the top is not. We have pvc/plasticlike base, foam cove and gorilla to put on base.
    Jun 2015
    Quarryville/PA
    58
    This pool came with black plastic-like sheeting (pvc?) The foam cove was placed on top of it as it is still attached. The plastic appears to have gone a cpl inches up the walls and then the cove on top (then the pad). What purpose does this serve and is it necessary to go up the wall? Can I just put the cove on the sand then the plastic ? Is the plastic supposed to go up the walls? It's certainly more difficult to seat the cove that way.
  20. Back To Top    #20
    Jul 2012
    Tallahassee, FL
    30,476
    I wonder if it is to act like a weed block? Kind of like a gorilla pad?
    My cove is sitting on the sand. I do not have any plastic or anything over the sand or up the wall.
    Kim
