Results 1 to 16 of 16
Thread: clever thing to go on the coping corner?
    Jul 2012
    Whidbey Island, WA
    397
    am fixing up the old pool
    started with water and that is now fine, thanks for the help
    so on to the surround, putting loose slates back down
    later work on the interior of the pool
    see pic and red arrow, attached
    the corner of the vertical and horizontal slates is very sharp, hard, hostile; also hard to grab to launch out of the pool
    is there any device that can be applied to the corner to render it friendly and grab-able?
    thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Jul 2014
    Peoria, IL
    389
    Re: clever thing to go on the coping corner?
    With slate you may be able to get a honing stone and take the razor sharp edge off??
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,570
    How?? How do you ever leave with that view?????????? WOWSER!
    Okay, Kim, deep breath and answer their question.................LOL
    A grinder? and carefully smooth the edges down? You may make a mess but it will be short term.
    Now back to looking at your view!!!!!!!!!!!!
    Kim
    Apr 2013
    Sacramento, CA
    2,769
    Frankly I'd vote against a grinder -- to high a chance of screwing something up -- the slate is not that thick.. Let me put it this way I would screw it up with a grinder.
    My suggestion -- not cheap is diamond backed sand paper -- 100 and 300 grit to round off the edge .
    Its not cheap: Z Gem Pads | Diamond Hand Pad But it does what you want
    Wow the view !!!!! Kimcats and I are coming over tomorrow and drink fruity alcoholic drinks, look at the view and "help" you with this task.
    Jul 2012
    Whidbey Island, WA
    397
    thank you all
    I could try to "sandpaper" or "grind" it down, and might do that but...
    I was hoping for something that could be grabbed by little (or old) hands
    I was thinking of something like
    round object that could be "glued" "mortared" "screwed" on
    like maybe 2" round rubber
    or maybe chip out the mortar between the vertical and horizontal and mortar a cylinder / rod in the crack
    or ???
    could also start over with new coping but not ready to go all that way as yet
    view is nice, even when cloudy, maybe even more fun when there are whitecaps on the Sound, then scary
    easy for a geezer to sit there and forget Iran, Greece, church in North Carolina, etc
    Jul 2012
    Tallahassee, FL
    30,570
    I worry that anything you put to be grabbed would cause a trip hazard coming into the pool as it would be raised a little.
    Kim
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I'm sorry about your dilemma, but is that your real view? They say life isn't fair, but seriously!!! You sure you didn't photo shop that???? Ok, ok, I'll take you at your word. My son lives near Portland, and I don't think he will ever live again in Texas. He loves the views!
    I'm a newbie on here - my pool isn't even finished. And I may not clearly understand what you're needing, but would the tile hand holds be a possible option? They sell those at the major pool tile places at stores and online. They are a 6x6" waterline tiles with what looks like a half cup (split vertically) on the face of the tile. Your fingers reach in and your palm grabs the cup for a hand hold - there's probably a better way to describe it. I can find a link for you if you like. But... that may not be an option - not sure if one of the existing waterline pieces could be removed.
    Best of luck. Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Jul 2012
    Whidbey Island, WA
    397
    trip hazard?
    good thought, probably best not do that, trip > hit coping > knock teeth out (or worse)
    waterline tiles with hand cups?
    gonna explore that further
    Casey's Avatar
    SW PA
    10,450
    I'm just here for the booze and the view....
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by Casey View Post
    me too
    oh
    and to add the bleach and acid every day
    Jul 2012
    Whidbey Island, WA
    397
    idea has emerged
    found a local person who can make custom tiles
    could make a right angle tile, 4" on one side and 6" on the other
    then cut back the current horizontal slates 4" and remove the vertical slates
    then lay in/on the custom tiles
    would solve two problems
    1) the sharp angle would be gone (now rounded)
    2) the vertical sections would not fall off
    and
    could add hand holds every third tile or so
    Jul 2012
    Tallahassee, FL
    30,570
    How in the world did you find him?? That is such a neat idea!
    Kim
    Mar 2015
    Mendon, MA
    273
    Clever! Isn't it great when you get just the right solution! So happy for you, good luck!
    18' to 29' wide by 37' long, 22K gal, Lagoon Free form, vinyl lined, in ground Pool with SWG, Hayward Cartridge 175 Filter, 3/4 HP Tri-Star, Gas fired 300 BTU heater
    Jul 2012
    Whidbey Island, WA
    397
    Quote Originally Posted by kimkats View Post
    Kim
    him is a her
    how did I find her?
    person x said call y, y said call z, z said call a, a said call b, b said "we could do this"
    she is a funky tile "artist"; does not think like an engineer
    in fact does not think at all; just free associates from here to there
    Mar 2015
    Mendon, MA
    273
    Quote Originally Posted by engrav View Post
    LOL, she is what I like to call and out of the box thinker, she sees the world differently than most, and her thought process is not linear, like an engineer. Probably comes across a bit flakey to most.
    Jul 2012
    Tallahassee, FL
    30,570
    I would LOVE to see some of her work! You know what else you could do? Maybe have the hand hold ones a different color so they stand out a little.
    Kim
