Hi all,
I am new to this forums, came across when I was doing a google search to figure out what might be wrong with my pool/spa as it is leaking water somewhere.
I am not a pool expert at all so please forgive me if I some of my questions do not make sense.
Lately I have been noticing that the pool requires lots of water to maintain it's level. So to make sure if it's a leak or just an evaporation; I performed a bucket test with duration of 24 hours with pump off. I noticed that the water level in the pool had dropped more than the water level in the bucket; therefore I am starting to suspect some sort of a leak somewhere.
Further observation tells me that the water level in the spa is dropping a lot compared to the pool [pump is off] so I am thinking may be problem is somewhere on the spa side? I then started walking around the pool and spa and equipment area but can not find any leaks or water.
However I did see two broken tiles inside the spa so I am not sure if water is dripping thru there and leaking inside the wall structure, pictures are attached.
I am also attaching the pictures of the pool equipment as I figured it may help with troubleshooting.
Thanks for reading and all your help!
