Results 1 to 8 of 8
Thread: How to calculate output from lbs to FC
    Mar 2015
    Harvey, LA
    300
    The Circupool brochure that came with my SWG says it (SI-45+) can output up to 2.1lbs of CL per day...how do I translate that to determine what the expected FC input per day? I'm also assuming that's with the device at 100%...
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Re: How to calculate output from lbs to FC
    Ues effects of adding chemicals and choose chlorine gas.
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    14 FC per day at 100% in a pool your size.
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    492
    or 0.58ppm per hour at 100%
    bring fc up to 3ppm with bleach or similar
    then i would start at 5 hours run time at 100%
    measure daily and adjust every third day until you find the level your pool likes
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Mar 2007
    San Rafael, CA USA
    12,082
    You could also type into a regular Google search "2.1 pounds per 17400 gallons in milligrams per liter" and you will get "14.4618102 milligrams per liter".
    Quote Originally Posted by chem geek View Post
    Note that that will only work for certain chemicals, such as chlorine gas, salt and pure cyanuric acid. It won't work for other types of chlorine, bicarb, calcium chloride, boric acid etc.
    Support the site
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by aussieta View Post
    Thanks---I just took this and calculated out the various percentages and made a chart to base numbers vs run times and cell settings!
    Jul 2013
    Waxahachie, Tx.
    448
    Why not convert lb to oz then divide by 24 to get oz/hour. Plug result in pool math to determine fc added to pool. Multiply by run time for total fc. Thats what I did and then made a quick reference chart.
    12 x 26 Viking FG IG, Bermuda Model, 3 1/2' to 5', 7000 Gallons, Diamond Series Maya, Hayward 1 1/2 HP Maxflo VS, Hayward Stay Clear Plus Cart Filter C17502(S), Hayward Aqua Rite SWG w/T3 cell, Color Changing FIBERSTAR Lighting, Aqua Bot Turbo T Robotic cleaner, Brushed Concrete with CCI Liberty Tan color, Taylor K-2006 test kit, Armor Foundation penetrating concrete sealer(lifetime warranty).
