Thread: iAqualink not communicating
    Jul 2015
    Canyon country, ca
    2
    Newbie here. Have the iAqualink used in wifi mode, and it sometimes fail to work with my iphone app. The webconnect device power and net led's are on but not the srv led. The wifi strength seems strong enough on my iphone's bars. Any ideas?
    Jun 2014
    15,008
    Re: iAqualink not communicating
    Hello and welcome to TFP! I see you haven't received a reply yet on your post about your Aqualink not communicating. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    are you saying the iAqualink aerial is not connecting or sometimes it drops out and not reconnecting? make sure the aerial has good line of sight to your wifi modem and there is not metal panels (eg metal fence or metal walls) blocking the line of sight as this will block the wifi.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jan 2015
    Anthem, AZ
    188
    i have to pull my iaqualink antenna out from the wall to get a better signal. you can go to the about page and get rssi which is the signal strength to your wifi router.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Jul 2015
    Canyon country, ca
    2
    The antenna is located about 75 feet from the router, through 3 walls. No metal that I'm aware of.
    Thanks for the advise. I'll check the about page.
