Thread: 12 inch straight pipe before flow sensor
    Mar 2015
    Harvey, LA
    300
    Why is it necessary to have 12" of straight pipe before the flow sensor? I accidentally left out some of this in the heat of the plumbing moment, and things seem to be working fine even though I'm slightly short on this. Is it such a big deal that I should be cutting and fixing this? Methinks if the flow sensor is showing flow when it exists and the cell is generating when the pump is on I don't need to cut and adjust...
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    38,237
    Re: 12 inch straight pipe before flow sensor
    Idea is so the water is not too turbulent when it gets to the switch. Likely does not matter unless you are trying to run at lower speeds.
    Mar 2015
    Harvey, LA
    300
    So basically, if the flow sensor feels flow is adequate when the 2 speed pump changes to low, then I'm ok? That's what I'm thinking that means...I didn't test it on low last night when I installed it, but I will check it out when it changes to low this afternoon...I run 6 hours on high then swap to low for the remainder of the 13 hour cycle...I know it's probably longer than the pump needs to run, but we like the waterfall effect and we also haven't had a chance to work out exactly how long it must run to do the job---and that would probably change now anyway with the new SWG.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Whats to work out? Run the pump for 4 hours and see if it clean enough for your liking.
    Mark
