Thread: Refilled pool - any help appreciated
    May 2012
    Hornbeak, TN 38232
    7
    Hi Everyone,
    I have a 30' 52" AG pool and put in a new liner. I have had pool filled for about 4 days now and have not added anything to it yet. Had to get a new pump/filter and just got it going yesterday.
    FC - 2.5
    CC - 1
    TC - 3.5
    PH - 7.8
    TA - 130
    CH - did not test
    CYA - Filled tube full and could still see dot - did this test twice
    How do I find out what my target readings should be for my pool to use on the pool math calculator?
    Any help on what I should do next would be greatly appreciated.
    Thank You!
    30' 52" AG pool, Sand Filter, Pool Rover Hybrid, TF-100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Refilled pool - any help appreciated
    Hi Kelvin,
    all your readings are not too bad considering new water.
    FC good
    pH, a tad high, but not to high.
    TA is ok for now.
    CH not needing in Vinyl liner pools
    CYA - you need to get some in there so that your FC isnt burned up too quickly by UV from the sun.
    Here is a link to recommended levels.
    Divin Dave,
    May 2012
    Hornbeak, TN 38232
    7
    Thank you Dave ! The link is exactly what I was looking for. Going to add stabilizer now.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    cheers Kelvin,
    Happy 4th!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Yep, looking pretty good to start off. One more link about Recommended Pool Chemicals and how to add them.
    A little more about TA and PH, they are interrelated. It is important to keep PH between 7.2 and 7.8. Your TA is a little high and could cause your PH to tend to rise. So keep an eye on PH and when it gets to 7.8 add muriatic acid to lower it to 7.2. This will slowly lower TA until they reach an equilibrium.
