Results 1 to 17 of 17
Thread: Water just went from crystal clear to milky
    Jun 2015
    Bedford hills ny
    46
    My readings are
    FC 3.4
    CC 0
    pH 7.6
    TA 120
    CH 140
    CYA 0
    I added bleach, soda ash and some Stabilizer
    Two questions:
    1) did I screw up my pool by adding soda ash and calcium chloride at the same time? Can I recover from this?
    2) I have been adding some stabilizer gradually (some in socks and some in the skimmer). I realize that it takes a week to register, how do I make sure I don't over shoot?
    20' x 50' AG gunite pool (no idea on gallons) built a long time ago. DE Filter w/Hayward Pump. Well water.
    Jun 2014
    15,255
    Re: Water just went from crystal clear to milky
    Hello! Your biggest concern right now (based on the readings) is that without any CYA, your FC is getting used-up by the sun really fast. Good you added some. We use the Poolmath calculator (link below) to figure out how much of a product to add based on your pool size. Until the CYA builds, keep your FC up to about 3-5. It probably went milky because you now have algae setting-in and will need to SLAM (link below). But you can't SLAM until your CYA is at least 30. So for now, it's just best to keep it from getting any worse by adding liquid bleach each day/evening to hold a temporary FC level just to keep things from getting worse.
    Once your CYA is close to 30, start the SLAM procedure immediately. Let us know if you have any more questions. Have a great day!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Question: are these readings before or after additions?
    If these are before, you didn't need the Soda Ash and your pH is too high which, combined with Calcium Chloride, can make it precipitate and get cloudy. Let things mix well and recheck pH and add acid.
    If these are after, just wait. It should clear up with time. Open a can of
    As far as CYA, what did you target and how much did you add? Without knowing the pool volume, there's really no way to know if you overshot or undershot or hit it right on the nose.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Use the tool at the bottom of Poolmath, Effects of adding chemicals, to calculate what the expected rise is for the amount of CYA you added. Enter the number of gallons at the top first.
    Pool School - PoolMath
    Also, check this out, Pool School - Recommended Pool Chemicals
    Jun 2015
    Bedford hills ny
    46
    Hi. Thank you. I have working against these levels.
    Plaster with SWG
    FC 3-5 (See chart) I am 3.4
    pH 7.6-7.8 I am 7.6
    TA 60-80 I am 120
    CH 300-400 I am 140
    CYA 70-80 I have no idea but it is sub 30 on my test and Leslie's says it is 0
    These readings were before I added:
    37oz bleach
    16oz ash
    100oz stabilizer
    I have added chemicals previously.
    I added about 188 oz by volume of stabilizer in socks while I filled the pool. I had a problem with a valve that led me to run a hose for 8 hours while the valve diverted water into my back yard so some of that was lost. I have since added 228oz into the skimmers (100 of which I just added).
    I also added bleach, soda ash and some calcium chloride previously. I have been careful about how much I added (and used tests and the pool math calculator) but I haven't kept great records.
    Jun 2015
    Bedford hills ny
    46
    Last thing I think my volume is 44k gallons. (43.4k actually).
    Richard320's Avatar
    Jan 2010
    19,071
    My advice is to wait a few hours with the pump on and let everything mix well and then recheck pH. Most likely it will be too high again, and you'll need to add acid to lower it, effectively cancelling out the soda ash. Your TA was already above the recommendation, so you shouldn't have added more via the soda ash.
    The problem is micromanaging the water. You were at 7.6 pH. That's within the recommended 7.6>7.8 and the high TA would guarantee it would rise on its own fairly quickly. The soda ash was completely unnecessary. Your CYA amounts shouldn't push you too high, but that will just have to wait a few days to get tested.
    Jun 2015
    Bedford hills ny
    46
    Thank you very much.
    Jun 2015
    Bedford hills ny
    46
    Ok.
    Today some CYA showed up!
    FC 3
    CC 0
    pH 7.5
    TA 110
    CH 270
    CYA 40
    Salt 2700
    Jun 2015
    Bedford hills ny
    46
    I am also beginning to think that the milky water may be the result of DE flowing into the pool....
    Jun 2015
    Bedford hills ny
    46
    Ok.
    FC 1.5
    CC 0
    pH 7.2
    TA 110
    CH 275
    CYA 45
    Salt 3000
    I will definitely add 154 oz of 8.5% bleach.
    Should I add the soda ash to increase the pH or will the high TA drive it up on its own?
    I am inclined to wait until Saturday to add more stabilizer and give the stabilizer I added last week /last weekend work.
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Hi fmbiv, if you look at the pool school recommended pool chemicals article, it says borax will raise ph without raising TA. Keep adding bleach daily to get up to 6ppm and don't let it fall under 4ppm now that your cya is 45, which is in range, don't add more stabilizer
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Richard320's Avatar
    Jan 2010
    19,071
    Quote Originally Posted by Fmbiv View Post
    Ok.
    FC 1.5
    CC 0
    pH 7.2
    TA 110
    CH 275
    CYA 45
    Salt 3000
    Your pH is already in range. The TA will push it up. If you raise it now, you'll just need to add acid sooner to get it back down.
    Jun 2015
    Bedford hills ny
    46
    Ok. I keep seeing 7.6-7.8 for plaster SWG pools.
    Richard320's Avatar
    Jan 2010
    19,071
    Yes, you do. And you also see TA 60-80. How do you plan to lower yours? I'm guessing you'll add acid to lower pH to 7.0>7.2... which is exactly where you're at already. Why add a chemical to raise pH and then add another to lower it? That's pool-store madness. pH will rise all by itself and then you can lower it again with acid and repeat the process until TA is down.
    Jun 2015
    Bedford hills ny
    46
    Awesome. Thank you.
    DFW, TX
    24,514
    Here is the process for lowering TA, Pool School - Lower Total Alkalinity
