Thread: Pool booster pump dead?
    May 2014
    Pflugerville, TX
    148
    So I switched to a robot cleaner about a month ago. However it already has to go in for repair so I dropped my crippled Polaris back in the water.
    Firing up the booster pump with my controller I don't hear any noise or feel anything on the return pipe for the pump after about a second.
    The polaris never starts moving.
    The pump worked a month ago but now it seems dead ?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    Jun 2014
    15,177
    Re: Pool booster pump dead?
    Hello and Mindflux! I see you haven't received a reply yet on your post about your booster pump. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
