Thread: Sand Filter Cleaning
    Six year old sand filter (Hayward s244t). This season I've been getting lots of very small tree particles in the pool. I have very large oak trees on 2 sides of my pool. The particles build to the point that my vacuum filter clogs and does not move (Polaris pressure side 165). I cleaned the sand filter yesterday by gently moving water hose thru sand (low pressure on hose) then let the filter fill and drain from the top for 10 minutes> I'm still getting the particles in the vacuum and pool. I did not drain the filter from the the bottom drain before starting cleaning. Do I need to drain first before cleaning or just clean for a second time since the filter has never been cleaned ?? THANKS !!
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: Sand Filter Cleaning
    No need to drain it first, but I seriously doubt you got it anywhere near clean in that length of time. Been there, done that at 5 year mark myself. Tookl forever to float all the gunk out.
    May 2015
    kingston springs, tn
    102
    Replace the sand if it is that bad. It takes a little effort but is really not that hard to do.
    18x36 IG vinyl 18,000 gal, Hayward super pump 1hp - 1.5" pipe, Pentair Triton TR-60 sand, Pentair Itellichlor IC-40 SWG, Pentair Intellibrite 5G 12v color LED light, Polaris 280 cleaner, Hayward Booster pump, Intermatic Power / Timers.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Might want to think about Deep Cleaning a Sand Filter
