Thread: Sudden up turn in running pressure - solved !
    May 2009
    Youngsville NC
    395
    Back in May, I posted a thread how my running pressure jumped from 16.5 - 17 PSi to 22 PSI. Solved the problem today.
    Way back in 2000 (or so - not sure exactly when), I put in a propane pool heater (this was when propane was $1 / gallon - my last fill last September was $4 / gallon), I had put in a brass check valve that used a spring. It had been fine all these years, until this summer.
    So, I had Ferguson's order me a PVC swing 1.5 inch check valve. This morning, I disconnected the pool heater and put in the new check valve. Problem solved !! Running pressure back down to 16.5 - 17 PSI, and flow out the returns nice and strong. I'm expecting vacuuming to work better now, also...
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Jun 2014
    15,186
    Re: Sudden up turn in running pressure - solved !
    Good to hear you resolved your issue. May be a good learning tool for someone else later. Have a great day.
