This Intex salt unit has not worked well since I bought it. At first it ran fine but after a week it started beeping the Hi Salt warning. According to instructions I emptied about 20% of pool and refilled. No more high salt warning. I took the pool sample for testing and my salt was way too low....2100 or so. So I then added the recommended amount and tested again and it was about 2300 and the high salt warning sounded again. I called Intex "customer support" and one re[ first told me it must be a faulty flow sensor. the next person dropped the call and the third call the rep said it may be the plates. I cleaned the flow sensor and also did the vinegar cleaning of the plates.
Started the salt unit and it was "working" for about 10 seconds then the hight salt warning started beeping again. Filter is clean. With Clorox and chlorine tablets I've got the pool pretty clear - the salt is still a little lower than the 3000 ideal.
Are these Intex SWGs poo poo? I'd happily pay more for a saltwater system that worked!
