Thread: Zodiac MX8 lay on it's back. Wheels turning, but going nowhere.
    Jul 2015
    Cape Town
    2
    My Zodiac MX8 works perfectly, until it gets to the walls, Then it turns onto it's back and just lay there. Tracks turning, but going nowhere. Can anybody help?
    Jun 2014
    15,261
    Re: Zodiac MX8 lay on it's back. Wheels turning, but going nowhere.
    Hello and welcome to TFP! I see you haven't received a reply yet on your post about your Zodiac. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
    Orlando, FL
    690
    Everything I quickly Googled indicates you need to increase the suction. I do not own this cleaner so I can not provide much more information. Here is a thread where this issue is mentioned. The Zodiac MX8 Suction Side Cleaner
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    do you have the float attached to the hose coming off the cleaner? it should be installed approx 18 - 24" up the first hose away from the cleaner. if you run the cleaner harder than the recom 2.5 (using their suction tester) then you will wear out the gears and cogs inside the machine.
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jul 2015
    Cape Town
    2
    Thanks for your reply. I checked the pressure, and that was in the range. It was one of my motors. I replaced both of them, and now it is running great again.
