Thread: Hard freeze warning in South Florida... Heat Pump question.
    Hello. There is a hard freeze warning for the Palm Beach, Florida area tonight. Temperatures are expected to drop below 32F. I have a AquaCal heat pump and I noted that it has a winterizing plug allowing you to drain the water. I read the manual and they suggest that light freeze can be controlled by just circulating the water through the pump but they suggest draining the system in any long term or hard freeze conditions. Any thoughts or true to life experiences would be appreciated. Personally I rather not touch any plumbing. I seem to have gremlins that cause leaks and such whenever I tinker with plumbing.
    Thanks guys / gals.
    15k Diamond Brite, Aquarite SWG, 1.5hp StaRite, Hayward Star Clear 17502, AquaCal heat pump, Pentair Great White pool cleaner
    Re: Hard freeze warning in South Florida... Heat Pump question.
    If you are looking at just one night in the 20s, then all you need to do is be sure to leave the pump running the entire time and you should be fine. If you are looking at a week in the 20s or a night in the teens you might want to do the entire winterizing thing.
    Oct 2007
    Valrico, FL
    542
    I live in the Tampa Bay area (north of Palm Beach). I have a pool controller that turns the pump on when the air temp gets below 34 F. It also opens the valve to the solar heater. I have had no problem with this system. For most of Florida, this freeze protection should be more than enough. However if you live in northern Florida, you might occasionaly have a problem.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    Mar 2008
    Central VA
    328
    Keep in mind that the heat pump won't run (at least mine won't) when it's under, I think, 50 degrees...but if you keep your pool pump on and circulate water through your system, I don't think one or two nights is going to cause you any trouble...just be sure to run out and drain your filter, heat pump, etc. if you lose power during the freeze.
    I was going to keep my pool open all winter (some people do, even in VA), but now I'm glad I didn't...one COLD winter, with temps in the teens again tonight, and we've already lost power once!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
    I am going to turn the pool pump on tonight and run it all night. According to the news this low should only be a one night occurrence. I just checked the pool water temp and it is 63F. Far from freezing I would say.
    Thanks all.
    Mar 2008
    Central VA
    328
    15 degrees here this morning
    I'm just hoping my concrete and vermiculite don't split down the middle
    haha
    Todd
