Thread: How to deal with chlorine levels that do not come down
    Jun 2015
    gainesville, FL
    11
    Hello -- and thank you in advance for your help.
    Here is the story -- Had some black algae. Dealt with that successfully. Then left town for 3 weeks. Friend added acid while we were away. Returned home to a beautiful looking pool, however tests show the following results....
    pH 7.5
    FC 22
    CH 300
    TA 100
    CYA 50
    I left the salt water generator at 50% while we were away, thinking the chlorine would come down.
    What should I do now?
    My first guess is to turn off chlorine generator until levels come way down. I know I need to increase CYA levels. Does having a pool screen reduce the amount of chlorine that gets burned off? Anything else I should be adjusting or thinking about?
    Thank you
    Marcite/Gunite Pool 13594 Gallons.
    Pentair Sta-Rite Cartridge Filter
    Saltwater
    TF-100
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: How to deal with chlorine levels that do not come down
    Yes, shut off the SWG. And yes, if things are screened you will lose less to sunlight. If there's a roof over that pool, you'll lose hardly anything to UV, so you won't need as much CYA and you certainly don't need the SWG on as long as you've been running it.
