Thread: Pentair clear pro lateral.
    Hi I'm getting sand in my pool. I have a pet air clearpro filter.
    I pulled the laterals and cannot find and cracks or anything broken
    This lateral had sand inside ,it looks like the filter fabric has pulled away slightly
    Any idea whether this would be enough to send sand back in
    Also when I look at the part for this it is 60$ plus ,anyone know if this is for one lateral
    Buying 6 would be more than I payed for the filter
    Thanks for any help
    31000 gal IG plaster pool,
    pentair clear pro sand filter
    2 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Pentair clear pro lateral.
    If there's sand inside the tube, it's obviously a big enough gap to pass sand. I'd just empty it out and seal up the gap with some silicon caulk or gasket goop and reassemble it.
    I caulked it .reassembled and it's running now with no sand issues
    2 hp pump
