Thread: Odd Salt test Results
    May 2014
    Merrimac, MA
    47
    Hi Guys,
    I'm using the Taylor salt test kit. On the 24th of June I tested and it was at 3,000 I tested again on the 29th and got the same result so I added a 40lb. bag which according to Poolmath would have brought me to ~3,200 ppm which is where I wanted to be. Today I tested and I'm at 2,800. I'm not sure how this could have happened. We had a little bit of rain, but I don't think it's anything that could have impacted the numbers by even close to that much. Is there anything else that could cause a 'loss of salt' aside from water replacement? My test kit is about a year old if that matters.
    Also, just to be sure I'm doing it right:
    10ml pool water
    one drop yellow
    drop of brown until water turns 'salmon color'
    multiply by 200
    Thoughts??
    Thanks!
    26,700 Gal., 18x36 IG pool with Vinyl. 1HP Hayward Super Pump; Hayward DE3620 Filter; Hayward SAS; TFT-100 test kit; Dolphin Atlantis Cleaner.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Odd Salt test Results
    I'm not familiar with the mechanics of that test. But, salt tests are inherently inaccurate. Most are +/- 400ppm. They are really only used as a sanity check to make sure your SWG is not way off, like 800-1000 ppm. One of the signs of a failing SWG is giving false low salt warnings. Most SWGs work fine with a wide range of salt, from about 2800 up to over 4000, even 4500 ppm. So, if the SWG is happy and making chlorine then we are all happy.
