Results 1 to 12 of 12
Thread: DPD test
    Jun 2015
    Phx Az
    13
    DPD test
    I have a Taylor k-2005 kit (along with the FAS-DPD) When using the DPD FC test it consistently shows much lower FC than the FAS-DPD test. This morning for example the FAS-DPD test read 12ppm FC. Using the DPD test with the X2 dilution it only read about 6ppm. Am i doing something wrong?
    Sep 2013
    Connecticut
    728
    Re: DPD test
    Sorry to ask the obvious, but did you multiply your DPD test result by two, to account for the dilution?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: DPD test
    My question as well...
    Also, DPD can bleach out at high FC levels, making it read artificially low. The OTO (yellow) test never bleaches out, it just gets darker and darker.
    Jun 2015
    Phx Az
    13
    Re: DPD test
    Yes i multiplied by 2 to make up for the dilution.
    Aug 2014
    Shallotte, NC
    693
    Re: DPD test
    Quote Originally Posted by particleman View Post
    This is hard to follow. What were you CC readings?
    Jun 2015
    Phx Az
    13
    Re: DPD test
    My CC is 0 according to the fas-dpd test.
    FC 12.5
    CC 0
    TA 70
    PH 7.5
    CYA 45-50
    Aug 2014
    Shallotte, NC
    693
    Re: DPD test
    I'm going to make a big guess and say you may have old reagents. Both R-0002 and R-0003 should be colorless. If they are tinted yellow, toss them (and the results) out.
    Personally, I'd listen to the FAS-DPD, if you have fresh reagents and are following the instructions to a "T."
    Jun 2015
    Phx Az
    13
    Re: DPD test
    Yep bad reagents just got back from the pool store bought new R0001 and R0002 and all is good. Thank you
    38,546
    Re: DPD test
    Why didn't you just trust the FAS-DPD? The DPD is the worst of the 3 chlorine tests IMO.
    Jun 2015
    Phx Az
    13
    Re: DPD test
    I just didn't want to use the FAS test every day. The best part was that the guy at leslie's gave me both bottles for $5 and said happy 4th of July. So im kinda glad I went. I do have one last question though. According to the pool math my FC should be 4-8ppm is it bad that I take it to 12ppm at night? I lose 4ppm on average during the day so by night time im down to 8ppm.
    38,546
    Re: DPD test
    That is overkill. You just want to keep it above 4ppm. Target 9 or so. The higher you go, the more you will lose.
    Jun 2015
    Phx Az
    13
    Re: DPD test
    Alright I will do that. Thanks for all your help
