Thread: pH @ 7.2 & Alkalinity @ 129... Pool Party on July 4th... What to do?
    Jul 2015
    Edmonds, Washington
    2
    Hi Folks... long time reader (3rd Summer w/ a pool), first time poster.
    We are having a pool party tomorrow... July 4th (and the cat's birthday). Excepting 15-20+ people plus a few kids (1-3 year olds).
    My pool chemistry readings are good, except for the alkalinity is a bit high... 129ppm.
    My pool chemistry app suggests that I add 3 quarts of of 15.7% - 10 degree Muriatic Acid. I could do this tonight, but fear it will knock my pH down too low by morning (currently sitting at 7.2). I only have about 1/3 gallon of Crown Muriatic Acid left (31.45% - 20 degree) around the house... and too late tonight to run out for more.
    The ultimate question is "Which route to I go...?"
    A. Do nothing. Leave it as-is so the pH stays intact. (Assuming here that Alkalinity @ 129ppm wont be harmful, especially to the kids).
    B. Add the remaining 1/3 gallon of Crown Muriatic Acid left (31.45% - 20 degree) to lower the Alkalinity; and count on 10-20 people splashing around tomorrow to raise the by through aeration.
    C. Something better that I am not considering.
    LMK your thoughts. Much appreciated! Kyle
    Re: pH @ 7.2 & Alkalinity @ 129... Pool Party on July 4th... What to do?
    Leave it as-is. There is nothing harmful to people about a high alkalinity, as long as your pH is in the proper range, which it is. The only problem with high alkalinity is it will cause your pH to rise faster, especially with aeration of the water from 15-20 people (plus a few kids) in the pool.
    Besides, a TA in the 120ppm range is what pool stores call perfect, so they can sell more "pH Down".
    25000-gallon semi-public IG concrete/plaster pool, Triton II sand filter
    750-gallon semi-public IG concrete/plaster spa, cartridge filter
    Volunteer pool caretaker for my condominium complex
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    488
    long term you know you need a good test kit
    short term, ta within reason has no affect on swimmer comfort or health
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    Jul 2015
    Edmonds, Washington
    2
    Awesome! Thanks for the peace of mind
    My current test kit is a LaMotte ColorQ Pool 7 Plus. I picked it up at the end of my first summer... and it has taught me a lot; along with the app on my phone that I plug the numbers into and spits back out recommended steps.
    Cheers!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Agree with all the others, leave it be.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Leave pH & TA alone, boost FC before and after the party. Don't panic if the water loses some clarity. Bleach and time will fix it.
