Results 1 to 7 of 7
Thread: Dishwashing liquid / dish soap. Squirt line across pool. Debris clusters at edges.
    Apr 2014
    USA
    25
    Has anyone tried squirting a line of dishwashing liquid / dish soap across a pool?
    I heard the debris will cluster at the edges.
    Re: Dishwashing liquid / dish soap. Squirt line across pool. Debris clusters at edges
    There is some effect like you are describing when certain chemicals form a layer on the water's surface. However, you shouldn't put soap in the pool. Even if you have a chemical that wouldn't be a problem, the effect is temporary and not worthwhile.
    Support the site
    Apr 2014
    USA
    25
    Quote Originally Posted by JamesW View Post
    Yes it is temporary, but will it help a person to remove floating debris?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    If it's a round pool, get a whirlpool going and everything will end up in the middle where you can bag it with a leaf rake or skimmer.
    We don't advocate putting anything in the pool if it isn't necessary. And if what you're after is an oily sheen, try a scumball.
    Apr 2014
    USA
    25
    No, not an oily sheen.
    I heard that because the debris supposedly clusters at the edges, time spent using a leaf rake or skimmer will be less.
    In my opinion, it's not worthwhile.
    Support the site
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    My skimmers work, so there is nothing collecting in my pool. Maybe if your pump was shot, you were waiting for a new one, you just mowed and blew grass all over your pool; then that may be a time to pull out the soap. It breaks the water tension causing everything to fall back from where it was put in. Then you could skim just around the edges. Under normal circumstances it's unnecessary.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
