Results 1 to 9 of 9
Thread: New pool set up
    Jul 2015
    Tamworth, NH
    5
    New pool set up
    Hi there! We have just put up an Intex above ground round pool, 15'x3'. We filled the pool about a week ago, and only yesterday began the process of treating the water. A bit late, and I could feel a little slime on the side of the pool, but the water was clear. I tested and corrected the Ph to 7.5. TH was 0, TA somewhere between 0-20, CYA 0. I thought adding shock would provide the FC, and increase the low values, so I shocked the pool. The water turned green almost instantly, so here I am!
    I have now visited pool school, and see the error of my ways. I think I understand what I should have done .. but what do I do now?? Can I correct the chemical levels, following recommendations from pool math (add the baking soda, calcium chloride and stabilizer) or do I need to dump the water and start over? If the water can be saved, how long after dumping the shock into the pool should I wait before adding more stuff?
    Thanks!!
    Intex round 15'x3' above ground metal frame pool, approx 4000 gal
    Sandra B's Avatar
    Aug 2011
    Shreveport, LA
    103
    Re: New pool set up
    Are you using well water to fill the pool, or city water? Also what kind of test kit are you using? And welcome!
    18,000 gallon freeform inground plaster
    Jandy 1.5 hp pump & .75 hp booster pump
    Aquapure SWG
    Pentair Triton II sand filter
    Legend pressure-side vacuum
    Jul 2015
    Tamworth, NH
    5
    Re: New pool set up
    Hi! Town water and Walmarts hth kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: New pool set up
    Welcome to TFP! Congrats on the new pool!
    You have two options with a smaller pool.
    Pool School - Guide for Seasonal/Temporary Pools
    Or if this is your "gateway" pool and you want to go full deal maintenance so you are ready for next bigger pool.
    Pool School - Test Kits Compared, I use the TF100 from TFTestkits.net
    Read up and ask some more questions.
    Jul 2015
    Tamworth, NH
    5
    Re: New pool set up
    just added stabilizer condition NOT in a sock! Oops! So now what? thanks
    DFW, TX
    24,509
    Re: New pool set up
    Don't clean the filter for a week. It will all get caught in the filter and dissolve from there.
    Jul 2015
    Tamworth, NH
    5
    Re: New pool set up
    thanks!!! safe to swim in??
    DFW, TX
    24,509
    Re: New pool set up
    Definitely!
    Jul 2015
    Tamworth, NH
    5
    Re: New pool set up
    Suuuuuuuuper! Thanks!
