Results 1 to 20 of 20
Thread: installed return behind upright
    May 2015
    Gulfport, MS
    109
    Somehow the wall moved while putting it up and now the return is behind and l an upright. Now I know the right thing to do is take it all down and redo it but my concern is that we have been literally waiting for months to have a few dry enough days that aligned with my hectic work schedule to install this and now it's calling for rain starting tomorrow for the next 4 -5 days and who knows after that. I'm concerned if I can't get the wall moved before the rain the foundation or posts could get compromised.
    I know people have added a second return to their metal wall above ground pool (and just leave the original return behind the upright) is this an option that would solve my issue and save my pool from the weather?
    May 2015
    Gulfport, MS
    109
    Re: installed return behind upright
    Fyi, my warranty will already be voided because I'm burying the pool 8" deeper than is covered under the warranty so that's not an issue. My only concern is safety and having read about others adding a second return to help with circulation I can't see why this would cause any structural issues.
    Secondly if I go this route, should I cut the hole into the same steel panel the original return and singer are on?
    Casey's Avatar
    SW PA
    10,457
    If your return is covered by an upright, your skimmer box cut out may also be covered or very close to an upright. I would check it.
    May 2015
    Gulfport, MS
    109
    The skimmer is fine. Anyone have any tips on how to get the aqualuminator apart so I can verify what size hole I need. The light came packaged together and for the life of me I cannot unscrew it. I am trying with all of my might but there is no place to grip it.
    12X20x54" Saltwater 8000 semi-inground, Waterway 1.5hp 2speed 22" Pump Sand Filter, Hayward Goldline Aquatrol HP SWG, TF100
    Casey's Avatar
    SW PA
    10,457
    I'm not sure.
    Personally, I'd reset the wall.
    May 2015
    Gulfport, MS
    109
    Quote Originally Posted by Casey View Post
    I'm not sure.
    No one has ever used an aqualuminator?
    Jun 2015
    Houston, TX
    89
    Quote Originally Posted by Straight6tt View Post
    Have you tried reading the manual?
    http://www.pentairpool.com/pdfs/6193...LumLightAG.pdf
    Look at page 2
    John
    AquaMaster Deluxe 8000 AGP, 5500 gallons, 12x18. Liquidator and Pool Rover JR.
    1st Pool so go easy on me I'm using a TF 100.
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    I have an aqualuminator. Let me know if you still need help. I didn't install it in the pool, but I removed it to close and then replaced after the winter.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    May 2015
    Gulfport, MS
    109
    Quote Originally Posted by jtburf View Post
    Look at page 2
    John
    Yes I have read the manual. There is no way to accomplish what it asks.
    It is impossible to remove to bulb retainer nut. I think I tore my bicep trying to turn it and it will not budge
    Jun 2015
    Houston, TX
    89
    Tried a large pair of channel lock pliers or pipe wrench?
    John
    S1ngram's Avatar
    Jun 2014
    304
    I went out to my pool and removed the back cover on my light. I think I know what you are talking about. When you push the bulb through the pool wall and then twist a plastic nut on....is that what you're asking about? When I installed it, it's only finger tight. Right out of the package you may need a couple of those lid gripper things to get a grip on things or maybe even some channel lock pliers. Just make sure to protect the threads. Is this what your light looks like?
    May 2015
    Gulfport, MS
    109
    NO my problem is how do i get the water jet that goes on the inside of the pool off so that I may stick the light through my pool wall. It all shipped together and I cant for the life of me figure out how to take it apart to put it through my return hole.
    I really appreciate all of your help.
    Casey's Avatar
    SW PA
    10,457
    Can you please post pics. Thanks
    Jun 2015
    Wheatfield, IN
    37
    I have the darkbuster which looks similar. You have to unscrew the retainer nut on the outside before you can unscrew the flow director on the inside of the pool.
    18' round above ground est 8600 /gal with Hayward sand filter filled with well water
    May 2015
    Gulfport, MS
    109
    Ok that's what I was trying before but it's apparently on ultra right because I cannot budge it with my hands. I'm going to try a pipe wrench tomorrow. Thanks for the help everyone.
    Jun 2015
    Wheatfield, IN
    37
    When I adjust my flow director it tightens up and I'm always having to loosen the retaining nut on the outside. It does get tight to where I can't get it by hand.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    I'm not sure.
    +1
    If you decide not to reset the wall you are going to need to fill the hole that is behind the upright so the weight of the water does not push the liner through the unused hole & tear it.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jun 2015
    Houston, TX
    89
    Drain your pool below the return line by 4" give or take, use a large pair of channel locks or pipe wrench to loosen the interior nut.
    remove and replace with the new light/return
    John
    May 2015
    Gulfport, MS
    109
    The pipe wrench worked like a charm.
  20. Back To Top    #20
    Casey's Avatar
    SW PA
    10,457
    So what are your plans and are they complete? Just wondering...
