Thread: Do I need to worry about CH
    Jun 2014
    White House, Tennessee
    17
    I have an AGP with a vinyl liner.
    See stats below.
    FC - 5
    PH - 7.7
    TA - 100
    CH - 80
    CYA - 0
    CC - 0
    Do I really need to try and raise the CH in my pool?
    "The ABC's of Pool Water Chemistry" page says it helps stone, plaster and concrete. Just wasn't sure if there was a benefit to my pool getting it up or not.
    I am currently doing the sock with stabilizer in the pool for the CYA.
    24' X 52" AG - vinyl - Install 6/10/15 - 14,650 Gal.
    Hayward Pro Series 16In. Sand Filter Sys. 100lbs. sand
    1HP single speed motor
    Tester - Taylor K2006
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Do I need to worry about CH
    nope. no need for CH in a vinyl pool.
    Dolphin E10 Cleaning Robot.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,572
    You are right. With a vinyl pool you do not need to worry about CH.
    Good job on adding the CYA.
    Kim
    May 2013
    Missouri
    53
    Wish I would have scrolled down a little farther--just posted the same question!
    June 2013 24 x 52 Sharkline Heritage AGP (13,500 gal), 2 speed 1 hp pump, 150 lb filter(?), TF-100 test kit
    My first pool ever, pool school student with lots of questions
