Thread: iAqualink or simple timer?
    Jul 2015
    Colleyville, TX
    34
    We have spec'd out a 16x34 rectangular pool with Jandy equipment - variable speed pump, cartridge filter, chlorine injector with heavy metals cartridge, and a Polaris robot - We have No heater (we MAY add a heat pump in the future). We have no Spa and 4 deck jets. We also have a auto cover to keep things cleaner, and reduce evaporation, etc and two LED lights.
    So the big question is we have spec'd an iAqualink system to control everything but I am starting to wonder what will it really be controlling?
    Would a simple timer set up which runs the pump slowly for a long period and runs the polaris for a few hours suffice? Seems like a lot of options and blinky lights to do very little actual automation. Oh first time pool person here...
    Apr 2013
    Sacramento, CA
    2,769
    Re: iAqualink or simple timer?
    I'd ditch the metals cartridge -- mine sits empty -- In most on here's view just another way to make money off of you.
    The beauty of automation -- and as you see I have Jandy automation -- is you can sit in the kitchen open the cover,turn on the pool lights and the deck jets - then walk outside and if you don't like the deck jets turn them off from your lounge by the pool. You never go over to the equipment pad.
    My family (wife and daughter at least) would kill me if I took away the remote. My wife had a pool and spa as a child -- no way would she go back to turning it all off and on at the pad.
    A robot is electric and thrown in when you want to clean and removed when you swim and isn't usually hooked up to automation. A pool sweep is controlled by automation -- it uses either the pool pump or a booster pump to clean.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    As Gwegan stated ditch the metals system. That is the last thing you want. You will love the automation. If it is raining we can turn on the system to filter stuff blowing in the pool. If we have swimmers, just grab the remote and extend the runtime to account for the extra load. Pool party and you want to change the pool lights, just grab the remote. IAqualink lets you control the system from PC's, Android, and Apple devices. Even better.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    malcolmb5325's Avatar
    Sep 2009
    Sydney, Australia
    166
    it is easier to program the VS pump thru the iAqualink rather than electric timers and as the other say you can sit in the house to turn things on and off. Think about your tv without a remote....gee i can still think about the days when we didn't have remotes....
    16,000lts Fibreglass, Magna Mineral Pool Water
    Jandy CV340 Cartridge filter, Zodiac TRi SWC, Z4 iAqualink, Jandy Laminar Jets, Solar Heating, Spa Jets with Jandy 1.5hp Epump operating everything.
    Jan 2015
    Anthem, AZ
    188
    Honestly it depends on price and how much work you want to do. If you need to turn a bunch of valves for like spa/waterfall then jandy aqualink is great. i have aqualink with iaqualink and love it, i can sit in the spa and adjust the temp as well as the blower and speed.
    most variable speed pumps include a timer, so you leave power on 24/7 and you program the timer on the pump for what speeds/hours you want.
    FYi i hate my polaris. i don't know who thought up pressure side vacuums but they are the dumbest thing ever. It shoots gravel/leaves into a bag and the rest of the fine particles all over the pool into a haze of cloudiness. your skimmer/drain then does the work of filtering it.
    suction side vac or robot is the only way to go. i'm in the process of converting my pressure side to suction and removing the booster pump. i think its another pool store scam.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
    Jul 2015
    Colleyville, TX
    34
    Thanks for the replies - we really do not have any extras like waterfalls or spas etc - but I think we will keep it in the mix mainly to use the pool cover via remote vs having to goto the pad.
