Thread: Intex SWG - 7000 or 15000 gallon model? Also sand filter size questions.
    zirconx's Avatar
    Jul 2015
    Nebraska
    20
    I'm getting ready to put together my first pool, an Intex 12x30, 1700 gallons. I plan on purchasing a sand filter and SWG for it. My reasoning is I want it to be as low-maintenance as possible.
    My question is, is there any benefit to getting the 15,000 gallon SWG vs the 7,000 one? They are about the same price. If the 15,000 is fine and will just run for less time, then why do they even make the 7,000?
    I was planning on getting the 1200gph Intex sand filter, is that adequate or should I be looking at larger one? I've read about larger pumps blowing the hoses off these smaller pools. I'm not sure at what size I'll run into mismatched tubing sizes either, I was hoping to avoid that.
    I should also mention I plan on upgrading to a 14x42 (3300 gallons) in 3-4 years.
    Thanks for your advice.
    Jun 2014
    15,212
    Re: Intex SWG - 7000 or 15000 gallon model? Also sand filter size questions.
    Hello and welcome to TFP! I see you haven't received a reply yet on your post about Intex SWG sizes. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
