Thread: Deep Cleaning Sand Filter - Question
    May 2014
    Troutman, NC
    19
    Having read the pinned post about deep cleaning, I have a question that I'm looking for ways to solve.
    First, a picture of the pump/filter pad.
    If I remove the retaining band around the multiport valve, I don't think I'll have much room to maneuver given the way the pipes are installed. Based on the experience of those who've done it, should I just remove the multiport and wiggle things around to do the work OR cut the three pieces of pipe and install unions when I put it back together ???
    approx. 13K, IG, Vinyl, sand filter, 3/4hp pump (single speed?), approx. 5-6yrs old
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Re: Deep Cleaning Sand Filter - Question
    I'd cut out those couplings that were probably installed the last time someone had to open it up and replace them with unions.
