Results 1 to 12 of 12
Thread: Old Filter Sand??
    Oct 2007
    Va Beach, VA
    41
    Old Filter Sand??
    I am getting ready to replace my filter sand and laterals. Would it be OK to use the old sand as the base sand for a brick patio? I am an aggressive recycler! Anyone foresee any problems with this?
    Also, how do I figure out how much sand I need?
    BBBB?-Bleach, Baking Soda, Borax, BEER!
    18' x 33' x 54" AG Pool, Vinyl Liner
    17,700 Gal
    Pump: Baquapure Workhorse Superflow, 2.5HP, 2 Spd
    Filter: Baquapure High Rate Sand Filter, 26 inch
    Baquapure Water Polishing System
    Proud new Papa of a Pool Rover Junior! Born 6/20/08
    30,421
    Re: Old Filter Sand??
    Tdog,
    No problemo on the recycle.
    Most filters have a specific amount of "freeboard" (open space) that works best. So they typically specify )in pounds) the amount you should put in. It will say "250 lb capacity" or something like that.
    Generally, it ends up being about 2/3 of the filter filled with sand. Check the website for your model and see what it says.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Check your sticker but I think that's a 200lb filter, tdog.
    Oct 2007
    Va Beach, VA
    41
    Thanks everybody.
    17,700 Gal
    I have a follow-up question on that topic. I don't know when my filter sand was last cleaned/replaced, as I bought my house 3 years ago and it came with the pool. For the first time today, I opened the filter top and checked the sand. There was some residu in it, a bit like what you would find in cat litter - but smaller and, well, less disgusting! I was wondering what is recommended in terms of cleaning/replacing sand, when and how often should one do it. Note that last year, I did not have any cloudy water or sand in the water problem, and the filter seemed to work write. I just want to know if I should do something before the beginning of this season.
    Cheers
    AG 24'
    Sand Filter
    Hayward 2 HP Pump
    30,421
    I would do nothing. Most of us here on the forum are not advocates of changing sand......altho some more so than others.
    My original sand is about 6 years old and I have no intention of changing it in my lifetime........I see no purpose. Others may disagree, but in my case, "It ain't broke, so........"
    Apr 2009
    Orange Park, FL
    104
    I second duraleigh's comments. My sand is maturing at 21 years!
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
    People who do replace their sand do so after 5 to 7 years. I don't normally replace sand unless something goes wrong and the sand is lost or seriously clumped.
    I like to open the filter up every two or three years and use a fine mesh strainer to sift out the debris on the surface. I also check that the sand is not becoming clumped up. If your chemistry is too far out of balance, the sand can become clumped up and if the clumping gets so that you can't easily break the clumps up by hand the sand will need to be replaced.
    Guest
    I recommend opening the filter yearly and 'washing' the sand with a garden hose:
    my-sand-is-channeled-how-to-fix-it-t7626.html (my post in the thread)
    de-vs-sand-filters-t3661.html (scroll down to my post in the thread)
    Thanks to everyone. I will keep the sand but wash it.
    This is really a great site. I joined last year on the advice of a friend and I will hopefully now run my pool trouble free for the entire summer. Just bought a SWG also, looking forward to hook it up.
    AG 24'
    Sand Filter
    Hayward 2 HP Pump
    Guest
    BTW, I am one of those that does advocate changing the sand because the erosion from the water flowing over it rounds off the sand and it's the sharp corners that help catch dirt particles.
    FYI... we used our old sand as a base for new pavers.
    2003 Marquis Euphoria - 400gal
