Thread: Any engineering types... I'd like your opinion on this custom hydraulic cover
    Jul 2015
    Atlanta
    39
    I'm buying a new home and it does not have a pool fence, and unfortunately with 4 little ones that is going to be expensive. I've been pondering my options and after 10 years of pool ownership in Georgia I've come to think that this thing I found on youtube may be the perfect solution. It seems simple enough to have built up. What are your thoughts? Design, difficulty, effectiveness, etc.
    Hydraulic Pool Cover - YouTube
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,633
    Re: Any engineering types... I'd like your opinion on this custom hydraulic cover
    I have never seen anything like that! WOW! I am going to love watching you do this.
    Kim
    Jul 2014
    Hope Mills, NC
    569
    Bet that is ungodly expensive, probably more than the pools cost.
    Given enough money and enough time, you can do anything.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Apr 2013
    Sacramento, CA
    2,769
    WOW
    Long ago and far away I worked in maintenance at a large frozen food factory -- almost all hydraulic motors. So from a mechanical standpoint I would think you could do that with two motors and a pump.
    It looks like it would work (well heck -- it does work) I too an concerned about the cost. -- It looks like they built the frame and then galvanized the entire frame.
