Results 1 to 9 of 9
Thread: Day two and beyond - daily routine
    Jun 2015
    cape cod, ma
    23
    Our pool is up! I tested Ph and Chlorine and they were spot on. The acid is filtering through the sock.
    Daughter is happily swimming
    So do I test anything else?
    What do you from day two and on? So, my daily schedule now that we've 'opened' the pool.
    Thanks!
    Intex 13" x 39"
    upgrade to Intex 1,000 GPH pump
    upgrade to Intex small 7,000 Gallon saltwater system
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,570
    Re: Day two and beyond - daily routine
    Got you covered!
    What test kit are you using?
    Kim
    Jun 2015
    cape cod, ma
    23
    Thanks! I'm using the 6 way test for right now. So it has a vial, color chart and a bunch of different bottles for drops.
    Intex 13" x 39"
    Jul 2012
    Tallahassee, FL
    30,570
    That is a good starter kit. It will at least get you up and running.
    Did you have any questions about the link I posted? I have it printed out and tucked inside my test kit for reference. In the beginning I had it hanging on my 'fridge to help me know what needed to be done day to day.
    Kim
    Jun 2015
    cape cod, ma
    23
    That's a great idea! Thank you
    Intex 13" x 39"
    Orlando, FL
    690
    When I first started out, I tested chlorine and PH everyday. Over time, I continued to test chlorine daily but PH became every few days. After three years, I am finally able to test chlorine weekly and PH twice per week because it has a tendency to creep up. I test my CYA/stabilizer a few times each season. The more you test in the beginning, the more familiar you become with your pool and you are able to catch problems, such as algae, before it catches you. Read Pool School and as many forum posts as you can. There is a wealth of information here and you will not regret reading any of it.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2015
    cape cod, ma
    23
    Thanks as always! you guys are so helpful!
    Intex 13" x 39"
    Casey's Avatar
    SW PA
    10,450
    If you get stuck, we're open 24/7.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    It's really not all that hard. Just keep up the FC and maintain the pH. Remove any debris that falls in.
    The water will get so crystal clear that a single flower pedal will show up in stark contrast and you will be forced to remove it immediately. And shortly after you reach that stage, you will hesitate to get in any pool but your own. So will your kids - they'll become pool snobs, too.
