Thread: Skimmer Pressure Uneven/ Vacuum Suction is great
    Aug 2014
    Coppell, TX
    6
    Hello All,
    After cleaning up the pool chemistry last year- I am facing another challenge this year:
    I cleaned up the pool filter and my suction vacuum is working great-I have two skimmers (one close to the pool equipment) and the other farther away. The skimmer that is close to the pool equipment is not working as hard as the other one and is not skimming very well.
    What are my options or should I just go the snake route?
    Thanks as always,
    Amit
    Location: Dallas/TX, 18000 gallons IG pool, Cartridge type pool filter, Hayward XL pool vac
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Skimmer Pressure Uneven/ Vacuum Suction is great
    That happens with my skimmers occasionally, usually the one farther from the pad for me. I turn the suction valve that controls drain/skimmers to all skimmers and put my hand over the opening on the skimmer that is working to force more suction through the other skimmer. That has worked pretty well for me so far.
    Aug 2014
    Coppell, TX
    6
    Quote Originally Posted by pooldv View Post
    Thank you for the input-I will try this method and let you know-I think I may have an air pocket.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Just cap the one with strong suction with something strong and unbreakable, like a plastic bowl or tub and see if the increased flow clears the line.
    Long term, you could drop a diverter valve in the strong one which would reduce the flow to equalize things.
