Hi
Not much to say regarding those numbers except that for most of your underlined numbers, the pool stores are typically very bad at measuring them (CYA, hardness, TA, etc).
I think if you got yourself a good test kit like a TF100 or Taylor K-2006, you'd find that doing your own water testing takes a lot of the variability out of the data since you are doing the tests and you don't have to bank on the gamble that the kids/person behind the counter is having a good day, is conscientious, etc, etc.
Lots of rain water certainly make pool care more challenging, but it rarely causes huge changes in water chemistry. As long as massive amounts of water are not flowing out of the pool, many of the chemical changes are transient dilution effects which will go away once the excess water evaporates back down to normal levels. Other chemical changes are easily corrected with some extra acid or chlorine additions.
The key to all of it though is doing your own tests and only adding that which is absolutely necessary. And, as you know, pool stores are not motivated by your best interests, they are motivated by their own.
