Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Thread: My test results
    Apr 2015
    New Bedford, MA
    65
    My test results
    I'm having a hard time with this..not sure exactly what I should be testing but this is what I got
    Fc is 0
    TA is 50
    Cya is 10
    P.h is 7.8
    14x42 summer escape metal frame pool with 2800 gph intex sand filter pump
    http://www.troublefreepool.com/calc.html
    summer scape metal frame AG pool 14x42, 3750 gallons
    INTEX Krystal Clear 2800 GPH sand filter pump
    TF-100 Test Kit Pool Calculator , cya-chart
    Pool school,recommended-levels
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    I see the links in your signature. If you read them I'm assuming you know what to do now.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    I just added 23 oz of bleach. I can't seem to get my Ta higher..is there any suggestions on that..also the instructions for TA will turn red I'm getting more of a pink is that right?
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Good on the chlorine you added. I would test it again after mixing to see if you got the FC that you were targeting.
    You can use Pool Math to determine how much baking soda to add to reach your target TA. (Note: my TA is 50 right now and I'm happy with it there as my CSI is good). I'm not sure you need to work on TA right now.
    Can you post Calcium Hardness test results? And Combine Chlorine test results?
    You probably want to increase your CYA if you are sure it is at 10 ppm. Use PoolMath to determine how much stabilizer needs to be added to reach the 30 to 50 ppm range. Recommended way to add stabilizer is to put it into a sock and hang the sock in front of a return.
    The pink color is OK on the TA test. (You add drops until the last drop does not cause a further color change, and don't count that last drop)
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    I'm guessing maybe 10 on cya it's cloudy when i fill it
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Suggest you add stabilizer targeting 30 ppm. It takes a week for the stabilizer to show up on the CYA test. So retest after a week.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    Ok so it's If it turns red I have calcium I got this color uploadfromtaptalk1435944022075.jpg
    2 drops of r-0012 and I got this blue uploadfromtaptalk1435944070136.jpg so I'm guessing I'm at 50
    Razorhog's Avatar
    Jun 2013
    Northeast Arkansas
    483
    Re: My test results
    Have you used anything else besides bleach for sanitation?
    What does the water look like?
    If you tested FC=0, you need to shock and probably SLAM depending on the rate of chlorine loss and what the water looks like.
    If you added CYA via stabilizer, how long has it been and how much did you add?
    Yes that color pink is normal and what they consider red for some reason.
    SLAM * Chlorine/CYA Chart * Pool Math * Pool School
    17.5k gal IG Fiberglass, Triton II TR60 Sand Filter, Jacuzzi Magum Force Pump 1.5 hp, 3/4 hp booster, Polaris 280, TF-100 Test Kit with Speed Stir
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Looks like you did the calcium hardness test correctly. I overlooked that you don't have a plaster pool so CH isn't much of a factor for you. I think you CH at 50 ppm is OK.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    My water is Crystal clear I haven't added stabilizer over a week
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    Quote Originally Posted by epro05 View Post
    Ok good to know
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Still looking for your CC (combined chlorine) test result. If it's 0.5 ppm or less, that will be good, and a slam may not be needed.
    If your unsure about the need to do a slam, perform the OCLT (Overnight Chlorine Loss Test).
    Just want to make sure you know that your FC level should never ever drop below the minimum shown on the CYA/Chlorine chart. Most folks test daily and add bleach daily to achieve that.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    Cc is 0.5
    Fc is 3.5
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    That's good I think. Try the OCLT tonight if you can, and if that's good, then you are in good shape.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    It looks like we might be up to 3 on chlorine
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Quote Originally Posted by angelover02740 View Post
    Not sure what you are saying.
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    I can't seem to find how to do OCTL test I just test the chlorine there is still some there but it's the lightest shade on the tester and oh is 7.2
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Re: My test results
    Here is the OCLT.
    You are letting your free chlorine get too low. Look at the CYA chart in your signature.
    Hopefully you've added stabilizer to target 30 to 50 ppm range. If so, adjust your FC level to match your target CYA level. Do this immediately. You are inviting an algae attack by letting your FC get low.
    Looks like you have a TF-100 kit. You should be using the FAS-DPD FC test to get a more accurate reading of FC.
  20. Back To Top    #20
    Apr 2015
    New Bedford, MA
    65
    Re: My test results
    I added stabilizer yesterday but I was told not to test for a week
