Is this even possible? Need to fix a suction side leak. We know where the leak is, so we will cut out the pipe that is causing problems (bad joint), but I need to keep the adaptor (grey pipe in picture).
Curious if i can use sand paper or steel wool to clean pipe once we have it out....
90,000litre, IG vinyl, 1/2 HP Tristar pump, Sandfilter, Aquarite T-15 ASG
