Thread: PH High, CYA Low...Good time for Trichlor?
    Jun 2015
    Houston, Tx
    19
    I understand all the potential problems with Trichlor, but if my cya is low and my ph is getting high would this be a good time to use some?
    Sep 2013
    Connecticut
    728
    Re: PH High, CYA Low...Good time for Trichlor?
    Trichlor does raise CYA and lower pH, so not a bad idea on the face of it.
    However, is there some immediate issue with your pool that you are trying to address (something beyond CYA levels and pH)?
    What is your CYA level, and how was it measured (i.e. test kit, pool store results, etc.)? If your CYA is really low, you will have trouble maintaining adequate free chlorine levels, especially if there is a lot of strong sun on the pool, which seems likely in Texas in July. Trichlor is not a very speedy way to add CYA...
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,406
    There are much better ways to do what you want to do. Here is a link to what we use.
    You REALLY need a good test kit if you do not have one. Look at my siggy to find the test kits we use and love!
    Kim
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'll take the contrary view. If you already own some trichlor pucks, use 'em up. If you have to go buy something, then buy CYA and Muriatic Acid.
