Thread: Newbie - question about chlorine tabs
    rebroth's Avatar
    Jun 2015
    Laurel, Md
    3
    Hello,
    So if I decided to use regular Clorox bleach as chlorine in my pool do I still need to use the 3 inch tabs and the bags of "shock" weekly?
    -- 28,900 gallons, IG, plaster, DE - Pentair FNS Plus 60 with Pentair WhisperFlo pump. Installed 2009. Polaris 360. Gas heater.
    Jun 2015
    Geneva, IL
    13
    Re: Newbie - question about chlorine tabs
    I'm a newbie too!
    The general idea of this method is to only put it what you need, when you need it, giving you safe easy to manage water at the lowest possible cost. So if you go with bleach, you don't need the tabs or the shock. Chlorine is chlorine and you just need to have the right about as matched up to your CYA levels.
    Recommend you read up on the pool school and order a TFP or K2006 test kit. Once you have that, you can test the water and the folks here will help you build a plan to convert.
    Best Regards, Tom
    18,000 IG, vinyl, TA-60 Triton II Sand filter w/DE, WFE-4 1 HP Pentair pump, Frog 5430 (off-line) feeder, Frog Mineral & Bac Pac (99% Trichoro-s-Triazinetrione), Frog BAM Algae @ open, gas heater, auto cover, k2006
    Jun 2011
    Long Beach, CA
    2,790
    All forms of chlorine do the same thing to the pool, what makes bleach the preferred choice is that it only adds a little bit of salt to the water and the others add CYA, aka stabilizer.
    TFPC is a method of pool care that teaches you to learn the pool water chemistry, which is very simple once you get it, and add only the chemicals that are needed to keep the pool in balance with accurate testing.
    Here are a few links to get you started:
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    Test Kit Comparison
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    You are on the right track, lose the pucks and shock and use a more pure form of chlorine. One more link to check out, Pool School - How to Chlorinate Your Pool
