Results 1 to 17 of 17
Thread: Cc high , ca low
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cc high , ca low
    FC-.6, TC-.9 , CC-.3 , PH-7.5 , hardness-133, TA-71, CA-4
    26700 gal, vinyl, SWG, Hayward Goldline controls, T-15 Cell, 20gpm/ft2 sand filter, 1 hp pump
    Sep 2013
    Connecticut
    728
    Re: Cc high , ca low
    Please let us know how these test results were obtained... Bringing sample to a pool store? Using your own test kit (and, if so, which test kit do you use)?
    Sorry, but what is is CA? Maybe CYA (stabilizer)?
    How does the pool look at the moment?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Used 4 way kit from ace hardware, and yes that's CYA, sorry.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I am not familiar with that test kit, but I am not aware of any test kit that can test CYA of 4. It should be more like 30, 50 or even 100 or more. If you have never added CYA/stabilizer to your pool and you have never used dichlor or trichlor pucks, shock or powder then you should add 30 or 40 ppm of CYA/stabilizer to the pool. In a sock in the skimmer and squeeze it a few times per day. Your chlorine will be eaten up quickly by the sun without it.
    It would be better to get a good test kit and test CYA with a reliable kit first. Pool School - Test Kits Compared, I use the TF100 from TFTestkits.net
    Chlorine level is set based on CYA level and Chlorine CYA Chart. It is very important not to let the chlorine level drop below minimum to keep the pool sanitized and algae free.
    Welcome to TFP!
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    im sorry guys i failed to mention in my haste this was a combination of reagent test and a "just to see test " from ace hardware. i would like to say that i found out first hand what has been said on this forum about in store water testing. brought a water sample to ace this morning and the first time the printout said i had NOTHING IN MY POOL. and i said to the guy" WWWHHHHAAATTT!!! " so after a retest it showed this FC-.6, TC-.9 , CC-.3 , PH-7.5 , hardness-133, TA-71, CyA-4. went back to town and retested again FC-6.1,TC-6.5,CC-0.4, PH-7.3,HARDNESS-166,ALKALINITY-75 , CYA-61. JUST GOES TO SHOW JUST BECAUSE ITS TESTED WITH IN STORE EQUIPMENT DOESNT MEAN ITS RIGHT!
    Jun 2015
    Glendale, AZ
    156
    Quote Originally Posted by Knjakeman View Post
    I am new to all this like you...but I can tell you for what it is worth, the pool store tests could be close (???) or so far off you would be headed in the wrong direction. I believe when you get one of the recommended test kits, you will be much happier knowing what your pool water really is.....just my 2 cents.
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    What should I do?
    FC-8.1 TC-8.7 CC-0.6 PH-7.8 TA-84 CYA-60 . My test kit will be here in a few days until then I'm using Ace hardware. Water is clear as a bell.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: What should I do?
    At this point I wouldn't do anything until you can verify these numbers with your own test kit. Clear water and adequate FC does not show any need for emergency action. Just keep the SWCG running to keep the FC up. You have a four way test kit, so keep an eye on the pH and adjust that down if it gets much higher.
    Support the site
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Knj
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    OK guys when I get home I will be using this brand-new test kit !! Will post progress later.
    Knj
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Suggest you not use it and return it if you can. That is not a recommended test kit and does not include the correct FAS/DPD chlorine test. You need the 2006 kit, not the 2005.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cc high , ca low
    OK going to take it back to Leslie's. And I just ordered the correct one from Amazon it will be here tomorrow.
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cc high , ca low
    Knj
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cc high , ca low
    Will post numbers this afternoon!
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Cc high , ca low
    FC-13 cc-1
    Ph-7.4
    Ta-130
    Ch-300
    Cya-60
    Pool temp -86
    FC is high from shock. Guess I need to let it dissipate. First time with K-2006, I think these numbers are as good as I could do for my first time. But I have been watching videos on utube so as to have a good idea of how to do it before hand.
    Knj
    DFW, TX
    24,485
    Looks good!
    Knjakeman's Avatar
    Jun 2015
    macon, ga
    30
    Hey can anybody tell me what the fine brownish colored stuff that collects in on the bottom of the pool. More in the little crevices and imperfections of the pool floor. When vacuuming manually, it sucks it up pretty effortlessly as it kinda breaks up cloud like. I'm hopeful its dirt. After I vacuum it it will be back in a few days. FC-5.5 CC-.25
    Ph-7.6
    Ta-100
    Ch-300
    Cya-65
    Pool temp -89
    Knj
