Thread: Pipe size and longer run to Equipment Pad?
    Jun 2015
    Hooksett, NH
    4
    Hi All, I have enjoyed reading many informative posts and now as I am fitting and plumbing my new Genesis fiberglass pool this coming week I was hoping for some advice.. The pool is a free form 16 x40. 2 main drains, 1 skimmer, 4 returns. I have shipping to me a 3 hp Intelliflow VS, clean n clear plus 320 cartridge, 250k btu heater, IC40 salt gen, intellitouch LC, 3 glowbrite leds..
    Planning to skim with dedicated line and main drains tee up. Returns... Thought long and hard about it and plan to run separate runs for each..ball valves at outlet to manage a leak and flow.. My run from the closest corner will be at the most 70' but then I must add the length of the pool 40' and 8' to eventually reach the skimmer. Main drains will be skimmer side and 8' depth.. I hope to run the pump efficiently but thinking that it will be working too hard.. Planning to use 2.5" for skim n drains. 2" returns.. If I put the equipment pad on skimmer side then it will be in view but the run from skim could be 30'.. I want the longer run because it is close to the house and out of site... Advice and analysis would be much appreciated. Thank you.
    38,284
    Re: Pipe size and longer run to Equipment Pad?
    Water pumps can not "work too hard". There is no issues installing the pump anywhere. Use larger pipe on longer runs, especially on suction side.
    Jun 2015
    Hooksett, NH
    4
    Thx JB, perhaps 3" pipe for suction?
    38,284
    Two 2.5" suction lines is plenty. If all returns are going to be separate, 2" may be overkill.
