Results 1 to 14 of 14
Thread: Can I shock the pool this morning?
    Apr 2015
    porter Tx
    26
    We are trying to get ready for the 4th. I have been slamming my pool for a week. Yesterday when it was time to vacuum, I got started and all to late realized my sand filter was blowing all the alge right back into my pool. We deep Cleaned the sand filter, and as of this am my ph is great, But I have zero chlorine. Can I shock it this am..(we always shock at night) and then vacuum again tomorrow? Thanks for the info!!
    Above ground, vinyl liner,
    15,000 gal.
    Hayward pump, sand filter, TF 100 test kit
    lefty51's Avatar
    May 2015
    East of Royals country western MO
    451
    Re: Can I shock the pool this morning?
    Quote Originally Posted by dawniellewesterman View Post
    15,000 gal.
    Yes, get some chlorine in there now. Don't let algae get a foothold. You say filter was blowing algae back into pool ?
    Si -central Mo. 32' x 16' -- 3'4" to 6' deep Vinyl liner - 16,500 Gals : Triton II filter -Duraglass 2 hp pump - 1 speed : SI-30 salt generator
    TF-100 with speedstir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Its safe to swim all the way up to SLAM level FC. So, no problem in raising it to that level.
    Divin Dave,
    S1ngram's Avatar
    Jun 2014
    Chrisman, Illinois (East Central Illinois)
    304
    I guess I would also ask what you mean by "shocking" your pool. If you've already been working on a SLAM for a week, shocking your pool, as I understand it will do nothing but add stabilized chlorine to your pool. Make sure your CYA levels aren't over the recommended levels or you will make your SLAM more difficult.
    27' round Seaspray Evolution, AG, 17,100 gallons, Pump: Hayward Power-Flo Matrix Dual Speed 1.5 hp, Filter: Hayward Pro Series High Rate Sand Filter, June 18, 2014, Kreepy Krauley Lil Shark, TF-100 test kit, Intex Krystal Clear Saltwater System
    Apr 2015
    porter Tx
    26
    Ok I will test my cya now...
    15,000 gal.
    Apr 2015
    porter Tx
    26
    At 20 on my cya test I can still see the dot. Is there an alternate way to get my cya up other than using the stabilizer from the pool store and doing the 72 hour run on my pump????
    15,000 gal.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    They have liquid stabilizer. It cost more but.........it works fast!
    Kim
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    you dont have to run the pump continually, but it helps speed the process up. The best way to speed it up though, is to squeeze the sock or bag, every once in a while and this helps get the CYA out of the sock and into the water. Ive added as much as 8 lbs in less than 6 hours by squeezing the sock a lot.
    It will take a few days for it to show up on the test though.
    15,000 gal.
    Divin Dave,
    Apr 2015
    porter Tx
    26
    You add your solid cya to a sock and put it in your skimmer basket?
    15,000 gal.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Yes, more here on adding chemicals to your pool, Recommended Pool Chemicals
    Chlorine level is set based on CYA level and the Chlorine CYA Chart. It is safe to swim when FC is above minimum and below shock level. FC should never be allowed to drop below minimum or the pool will be unsanitary, allow person to person disease transmission and algae growth.
    Sep 2013
    Connecticut
    728
    15,000 gal.
    Just a bit confused by the above (i.e. shocking only at night)... If you have been following the SLAM process for a week, haven't you been adding chlorine (bleach) multiple times during the day in order to maintain your free chlorine levels? Allowing the FC to get too low allows the algae to recover, and can make the whole SLAM process take much longer.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    Apr 2015
    porter Tx
    26
    I was only shocking at night because of my consern of the sunlight eating it up, this idea was coming from some bad information I received last yr from the pool store. Before I found you all, and before I knew what cya was. When we moved here last yr, the previous owner had the pool for 15 yrs and told us, all I ever use are these test strips, you don't have to worry about anything besides chlorine and PH. 😦😦😦 I am learning so much from you all, thank you so much! I shocked the pool this am.
    15,000 gal.
    Apr 2015
    porter Tx
    26
    Also. The previous owner let the pool go green every winter. We are trying to rise above the misinformation and terrible attention this pool,has received in the past 😀
    15,000 gal.
    Sep 2013
    Connecticut
    728
    Can you share your test results, perhaps from the last few days, to give some insight into how the SLAM is coming along?
    About how often during the day are you testing FC and CC, and how often are you adding bleach now? As you probably are realizing from reading on this site, it is very important to maintain FC levels during a SLAM (shock level and maintain).
