Thread: pool store test results vs mine, interesting
    Jun 2015
    Greenwell Springs, LA
    45
    7/2/15 Pool store results:
    FC 0.7
    CC 0.0
    CYA 68
    pH 7.8
    CH 303
    TA 120
    Adjusted TA 100
    7/2/15 my Taylor K-2006 results, 1 hour prior
    FC 1.4
    CC 0.2
    CYA 70
    pH 7.6
    CH 350
    TA 100
    I have been using my own results and treating my pool according to them. Just wanted to see how that BioGuard disk they squirt the sample into and then spin around in a centrifuge would compare. Interesting. And yes, I brought my Cl back up to the needed level. Been raining everyday for nearly 10 days!
    Just thought I would share.
    25K gal vinyl liner built 2012, 18x36 IG, deep end, Pentair 1.5 HP single speed pump, Pentair Tagelus 325lb sand filter, Kreepy Krauly Legend auto cleaner, inline chlorinator, one skimmer basket, 2 main drains, 4 return jets, 2 water sprinklers, newly acquired Taylor K-2006, sample sizer and speed stir.
    Jun 2014
    15,092
    Re: pool store test results vs mine, interesting
    Actually, those aren't too bad a comparison for some I've seen. In my personal experience, I've seen some comparisons waaaaay different. Always good to be in charge of your own pool.
    Jun 2015
    Rocklin Ca
    78
    Actually I haven't had the pool store check mine in about a month since I joined TFP, but their last results were pretty close to my first TF-100 test.
    In ground 20,000gal - pebble-tec - salt, Intelliflo pump, Sta-Rite filter 450 sq ft ,Hayward 6060 booster pump, non functioning Aqua Rite SWCG, TF 100 test kit.
