Thread: In ground return repair using hose & Clamps?
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Ok, so I just opened up the pool and one of the returns was leaking like a Geyser .
    Removed a bunch of the pavers and found that when my pool repair company re-installed the Loop-Loc last year they drilled into one of the returns to set one of the anchors.
    After some digging, cutting, etc. they repaired the return by replacing a section of PVC. They glued one end and used reinforced hose with double SS hose clamps on the other end. I have used reinforced hose with double SS hose clamps in marine applications where pressures have been far greater then my pool system can create so Iím comfortable with the process, But I didnít bury them in the ground?
    Has anyone used or seen this type of repair for pool use?
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Dec 2009
    Central Massachusetts
    2,690
    Re: In ground return repair using hose & Clamps?
    They should have used a shielded no-hub coupling. Basically the same thing, but with a metal band around it.
    Ideally, a pvc repair coupling would have been the ideal thing to use.
    Is the pipe already buried?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Jun 2014
    Long Island, NY
    340
    Pipe is not buried yet as my paver guy wants to do all the backfill and re-install pavers. Expect him here sometime next week
    I agree the shielded no-hub would have been a better choice.
    Spoke to the Pool Company and their standing firm on the repair and are guaranteeing it. They have been stellar with all of their work, have been in Biz for 30+ years, just builds & repairs, no maintenance work. They’re picking up all costs involved
    I think I cut a larger diameter PVC pipe and clam shell it around the hose to protect it from rocks, whatever.
    Thx
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I had a collapsed pipe under my skimmer and had limited pipe and room to work with and did the same thing. Everyone i checked with said it would not be an issue.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    I used a telescoping coupling and it worked great.. it was on my lawn sprinklers that are at 70 to 75 PSI...
    here is a 1.5 inch Red Flag Products 1-1/2-Inch PVC Slip Fix Telescoping Repair Coupling with Union (White) - - Amazon.com
    here is a 2 inch Amazon.com : Red Flag Products 2-Inch PVC Slip Fix Telescoping Repair Coupling with Union (White) : Patio, Lawn Garden
    here is a video about them, I used the second 1 shown..
    here is my fix
    Dec 2009
    2,690
    That's the proper fix.
    However, the Fernco should be ok.
