Thread: Can't get PH up
    Jun 2015
    Bloomington
    1
    Can't get PH up
    Hello I just finished converting my pool from baquacil to SWG. I got through it ok thanks to the help of your site. I only made one mistake. I tested the PH in the middle of it. Of course it was extremely high so added some muriatic acid. The conversion is now done everything looks great except my PH is so low the test just comes back a bright yellow and my TA is so low when I add the indicator to the sample it turns red instead of green. I'm using a Taylor k-2006 test kit. I've added almost a box of borax and it doesn't seem to be changing any. Is there something else I should be doing? Or just keep adding borax?
    other numbers
    FC: 1 just hooked the SWG up last night and I was afraid to boost it until I saw what it did because I already had some chlorine in it. So, I will boost that to increase this
    CH: 80 adding increaser
    CYA:30 been adding this so I will put a little more in.
    7,600 gallon above ground; 4 lb DE filter with 2,280 gph flow rate; index 120v Krystal clear saltwater system cg-28669
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Re: Can't get PH up
    Hi, welcome to TFP! You can finish off the box of borax and then try using baking soda to raise the TA and point a return up to aerate and raise pH if it is still too low to register.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,657
    Re: Can't get PH up
    Maybe this will help. Work on that PH and TA fast. With it being that low it can cause big problems.
    Good luck!
    Kim
