Thread: jandy retrofit igniter kit
    Dec 2014
    bayport, new york
    12
    Jandy decided to relocate their LJ series mini-Norton 601 igniter from the igniter box to the burner itself, they made this custom made non-generic 4 inch long mini igniter R0367100 NLA and made it available only in the R0449800 retrofit kit. Why not just take the NLA igniter that comes with the kit and put it in the original igniter box instead of the blocking plate that comes with the kit or just use an LLD400 box with a full size large igniter? Where does the flame sensor relocate to when you block off the igniter box?
    in-ground gunite 20X40 and spa 8X8, combo plumbing 2 Jandy valve actuators RS 8 CPU rev T, touchlink wireless 1 circulation pump, single heater, single filter, DE 72 Hayward filter with multiport valve, 3 of 2 HP Hayward pumps , 2 air blowers, Jandy LLD400N heater, Jandy mineral feeders and chlorine generator combined unit with high flow bypass external plumbing, Hayward DE separation tank, 2 Jandy LED large pool lights, one Pentair spa LED
    Jun 2014
    15,178
    Re: jandy retrofit igniter kit
    Hello Mitzie! I see you haven't received a reply yet on your post about the igniter kit. I just wanted to let you know we haven't forgotten about you. This reply should get your posting updated back to the top of the queue where hopefully someone experienced with your specific question can provide some constructive answers. Thanks for checking-in with TFP, and have a great day.
