Results 1 to 7 of 7
Thread: Advanced Search Error
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    The admin crew may already be aware but just in case...there is some error code being generated above the page header when Advanced Search is selected. See below. It occurs in IE and in mobile Safari.
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    38,456
    Re: Advanced Search Error
    It was added to the list. Happens in Firefox too.
    May 2015
    Wildorado Texas
    252
    PHP warnings like this can crop up when the php version of the host server is newer than the vBulletin software package running on it. These aren't actual errors, they are just warnings of depreciated php values the scripts are using. There are two ways to handle it and I recommend the first one.
    1.) Go into the config.php file and add this under the <?php line:
    Code:
    define('SKIP_ALL_ERRORS', true);
    This will bypass all (non fatal) error reporting.
    2.) Upgrade your vBulletin installation to latest version of 4, which is vB 4.3.3 <--- This can be fraught with problems regarding compatibility of some add-ons, I do not recommend this be undertaken lightly and if it is undertaken, do it during the winter when your traffic is lower.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Thanks Red!
    Essential Links:
    May 2015
    Chicago, IL
    508
    I see this is still not fixed.
    Mar 2007
    San Rafael, CA USA
    12,082
    This seems to be fixed now, as far as I can tell.
    38,456
    Yeah I noticed this got fixed yesterday or today.
