Results 1 to 9 of 9
Thread: R-0011L indicator?
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    R-0011L indicator?
    On the R-0011L Calcium indicator liquid is the fluid kinda thick or has my gone bad? I don't rememberwhat it was like when I first got it. I've only had it about 6 months and has been stored in a cabinet in my garage, so it has not been exposed to sunlight or in extreme temp's.
    16,500 gal Roman end with PebbleFina finish
    4 x 160 intelliflo pump
    Easytouch controls with an IC40 chlorinator
    Sta-rite cartridge filter
    A & A infloor cleaning system
    Pentair 5g LED pool light
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Re: R-0011L indicator?
    My kit is only a month old and that is the way mine is so I hope it is not bad.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    gtm's Avatar
    Aug 2008
    St. Petersburg, Florida
    201
    I left my kit outside for a couple of days and had a similar observation. The temps were lows in the mid-40's to highs in the mid-60's; mid-60 when I did the test. The indicator came out sort of syrup-like and pooled on the bottom. Hadn't seen that before. I went ahead and did the test and it worked same as usual, meaning I got the result I expected. I did, however, have to mix it a little longer before starting the test.
    Was your garage temperature in that range by chance? Or is it heated? If it's heated, none of this is relevant, of course.
    I assumed that this was just a temperature effect on the viscosity, but that the test was still okay. But I'm curious what others say. I don't know much about these things.
    Gary
    15,000 gal. IG fiberglass pool w/ 1 hp Hayward Max-Flo and 250 lb. Hayward sand filter
    Located in St. Petersburg, Florida, and enclosed in a birdcage
    SCCS's Avatar
    Sep 2008
    Left coast
    79
    gtm
    My garage is not heated but stay's fairly stable in temp. Running from the 40's in the winter to the 80's in the summer. I do have the same results that you do. It will pool in the bottom and extra mix time is needed.
    30,421
    The R-0011L is pretty thick even at room temperature. To my knowledge, the viscosity is irrelevant to the accuracy of the test.
    As an aside, I would rather see your test kit in a controlled environment (inside) rather than in the garage. I believe it increases the longevity of all the chemistry.
    (PS - I guess if I was completely candid, my first choice for test kit storage would be a 450 degree oven.......my refill business would be phenomenal!! )
    Taylor stresses that stable temperatures are important for long term storage of reagents. Recommended storage temperatures are between 36°–85° F, with lower temperatures being better. However, you don't want the temperature fluctuating a lot. For example a test kit should not be stored in the fridge and taken out and put back in regularly. That would be worse than storing it at the higher end of the temperature range. See this Taylor document for more information.
    gtm's Avatar
    Aug 2008
    201
    Dave, viscosity was probably the wrong word. I was thinking about how quickly it would mix with the pool water. There's very likely a better description for what I was seeing.
    Jason, I think we're at the low end of the proper storage range, but I haven't read the Taylor link that you cited. I just wonder if having the reagent at the lower end of the range might affect the mixing time. Just thinking out loud, though.
    SCCS - listen to these guys. I'm a rookie! Just trying to help.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    When it's cold, calcium indicator will fall to the bottom of the vial like bb's and stick to the bottom as you try to swirl it. As has been mentioned, storing the kit and doing the testing indoors will prevent that.
    Guest
    Remember that to do this test properly takes a LOT of swirling (about 20 seconds after the calcium buffer, enough swirling to mix the indicator, and 20 -30 seconds between EACH drop of titrant)! This is one test that a magnetic stirrer really helps speed up!
