Thread: Sand swap help?
    Jun 2015
    madisonville, tx
    35
    Sand swap help?
    I have a Hayward S244T sand filter. This is my first time changing out the sand. Disconnected the unions on the pipes and took the collar off the multiport valve expecting to find a center pipe that I can reach around to remove the sand but what I find is this
    Jun 2015
    madisonville, tx
    35
    Re: Sand swap help?
    Jun 2015
    madisonville, tx
    35
    Re: Sand swap help?
    How do I get around this to remove sand or remove it without damaging laterals. It seems pretty solidly placed on there. Not sure if it's glued or how it's assembled
    Re: Sand swap help?
    Quote Originally Posted by sealy99 View Post
    Sent from my SAMSUNG-SM-G870A using Tapatalk
    Just had mine apart yesterday--- That part just lifts straight up and off...
    21000 Gallons I/G,,Vinyl,, 1.5 H.P. Hayward Pump,, Hayward Sand Filter S244T.. Liquidator.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Sand swap help?
    Here is a tutorial on cleaning a sand filter that will help.
    Deep Cleaning a Sand Filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Re: Sand swap help?
    That black piece should have lifted out with the valve leaving the white pipe sticking up exposed. Wiggle on it until it separates.
