Thread: Re: iAquaLink Offline Frustration
    Jul 2015
    Thousand Oaks, CA
    1
    I have an iAqualink v1 and its been working fine for a while but recently it’s been acting up. It seems to go into this strange state where from my Samsung S5 the App shows “Offline” line but if select “Web” it will shows some of the correct buttons but not all of them. Some of the buttons work others don’t. If I login via a computer into your site the system seems fine and I can use it without any issues but the phone app still shows “Offline”. The unit itself looks OK with all 3 lights lit. If I unplug/restart the unit it starts working normally again for a few days and then stops again. Any help would be appreciated.
    I think they messed up the App in a update.
    I'm having the exact same problem. Been working fine up until now. The iOS app says Offline but I can control it fine with either the web portion of the app or via the computer. Has anyone figured out how to fix this?
    Thanks
    13,000 gallons (30' x 20' oval), Inground, Pebbletech, Jandy 60 sq ft DE filter, Jandy ePump (variable speed), completed Sept 2013, Talor K-2006 test kit
