Results 1 to 13 of 13
Thread: Getting cloudy
    May 2015
    Jefferson/ga
    2
    Getting cloudy
    We have had a bunch of rain the last week. I have continued to check and keep levels with in range. Should I do? I just slammed. Reading before slam were as followed.
    CYA=45
    FC=4.6
    CC= 0
    pH=7.6
    TA=100
    CH=50
    What else should I do? I don't want to lose it. It has been getting a little cloudier then last 2 days. Has a slight green/blue tint today.
    12' X 48" AG
    Intex Krystal Clear 3000 GPH Above Ground Pool Sand Filter Pump
    6/1/2013
    Taylor K-2006
    No SWG
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Getting cloudy
    Cloudy water is nearly always the first sign of algae. Algae is nearly always caused by chlorine level dropping below minimum for your CYA level. First, Cya should be rounded to the next 10, the scale is logarithmic not linear. So, assume 50. Minimum FC is 4 and chlorine should never drop below 4. Target is 6 and should be kept at 6 at all times. I usually go a little higher to be cautious. Especially if there will be lots of swimming. It is safe to swim with chlorine up to shock level of 20. Chlorine / CYA Chart
    At this point you can Perform the Overnight FC Loss Test (OCLT) to see if there is organic mateiral in the pool. Take FC up to 10ish for this test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Getting cloudy
    You're doing it - Nip it in the bud!
    Round CYA to 50 and shock level is 20. Test and raise it again before bed and leave the pump on overnight. Test and add some more early in the morning when you have your morning coffee. You can beat it back before it gets any worse. A jug in time saves nine.
    DFW, TX
    24,450
    Re: Getting cloudy
    Is that the first TFP limerick?
    Richard320's Avatar
    Jan 2010
    18,967
    Re: Getting cloudy
    Quote Originally Posted by pooldv View Post
    TFP proverb.
    Limericks usually start out with something about Huxham...
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Getting cloudy
    Keep SLAM'ing and run that pump!
    18,400 gallon 28' round above ground pool sand filter 2013 K-2006 2014 new Hayward pump 2018
    My pool turned green the second year, K-2006 saved me, Trouble Free Pool set me free
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Re: Getting cloudy
    Hi mayor what are your readings after the slam/today? How many days did the slam process take?
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    May 2015
    Jefferson/ga
    2
    Re: Getting cloudy
    I just took readings today.
    CYA=50
    FC=15 (a drop of 6 over night)
    CC= 0
    pH=7.6
    TA=100
    CH=50
    I just slammed again. Raising it to 24
    First slam was yesterday just before dark
    How much should I vacuum? Is it more important to filter or get the dead stuff off the bottom.
    Apr 2013
    North OKC Area
    300
    Re: Getting cloudy
    Based on your questions and past tense use of SLAMMED when you haven't completed a SLAM, I suggest reading the SLAM process again. It's easier to understand once you've started the process.
    Pool School - SLAM - Shock Level And Maintain
    17,100 Gal 27' x 52" AGP steel wall vinyl; 44gpm Cooper sand filter; Hayward 1hp sp1580 single-speed; 1.5" plumbing, 1 skimmer/jet, inline chlorinator.
    Chlorine / CYA Chart | SLAM Process | Chlorine cost/fl. oz calculator
    Apr 2013
    North OKC Area
    300
    Re: Getting cloudy
    SLAM:
    1) Test the FC level as often as possible (at least twice per day, but no more than once per hour) and add chlorine to raise FC up to shock level.
    2) As things progress, you will lose less chlorine each cycle and can add chlorine less frequently.
    3) Brush and/or vacuum the entire pool once a day.
    4) Backwash or clean the filter as needed.
    5) Vacuum up debris as needed.
    6) Run pump on filter mode 24/7.
    You are done when:
    1) CC is 0.5 or lower;
    2) And you pass an OCLT (ie overnight FC loss test shows a loss of 1.0 ppm or less);
    3) And the water is clear
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Getting cloudy
    Mayor,
    How about an update? Are you losing chlorine overnight? Got any pics?
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Getting cloudy
    Bueller?
    Anyone?
    It seems the Mayor of JTown has gone on vacation. He added two trichlor(?) tabs to his skimmer basket and skipped town. Should I use his test kit to confirm levels or just let it stew?
    Skitch's Avatar
    May 2015
    Athens, Georgia
    111
    Re: Getting cloudy
    Like a good neighbor, Skitch Fester was there.
    I tested and added chlorine for the Mayor while he was out of town.
    Needs a good vacuuming, but Trouble Free rules!
