Thread: Pavers or no pavers
    Jul 2015
    fowlerville mi
    1
    Pavers or no pavers
    The wife finally talked me into a pool for the kids. My last house had a pool when i bought and the bottom rails were set on pavers. Most of them had shifted over the years and the top rail wasnt very level. Our new pool is a 30' round. Its a resin frame with steel wall. Currently the location is level and compacted. The outer 2 feet were trenched and 4 inches of crushed limestone base was put in and compacted twice with a walk behind compacter. Now my question is should i install pavers under the bottom rails all the way around or will the compacted base be good enough? We live in michigan. Thanks for the help
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    Re: Pavers or no pavers
    Welcome
    With the limestone base I'd just put pavers under the uprights. Since mine was just leveled dirt I put partial pavers 1/3 of the way between uprights, so I had two partials between each post. It's been stable for 3 years now.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Jun 2014
    Northeast Alabama
    98
    Welcome to the club!
    We have a 33' and used the pavers under the uprights only. Once the base was level and compacted, we laid out the bottom rails, marked on the ground where the feet go, moved the rails then dug the paver space down to flush with the base. Put up the wall then started adding the sand base. Pool has been up a year, very solid and within 1/2" of being level all the way around.
    33 Round AGP, 26K gal, vinyl liner, 1 HP single speed pump, 1 Hayward wide mouth skimmer, Pentair sand filter, Taylor K-2006 test kit, Red Leopard Orbit suction auto vac, Pool School, TFTestkits, PoolMath, Support this Site!
